TRIPLE QX good oil?
1 reading
36K views 11 replies 7 participants last post by  Emm
Some of you may know ive started changing my oil every 7k now, thats every 3-4months for me, its getting abit pricey to keep buying Castrol all the time, anyone heard good news about TRIPLE QX Fully Synthetic (For PD engines), sells quite cheap on EuroCarParts in 5L guise? Hits the approved spec for my 118d...
#2 ·
We use a Triple QX fully synthetic 5w30 at work and have had no problems with it. It's about the specifications it meets more than anything, if it meets the specification of the recommended oil in your car then you should be fine.
#4 ·
#6 ·
excellent cheers Marco :)
#8 ·
NVM said:
It is ECP's own brand.. therefore exclusive to them and cheaper. It does meet the standards... but there are better oils out there :arrow:
Anything you can recommend cheaper than castrol?
#10 ·
Hi all, I've just bought a 199 lt barrel of this for work as have heard quite good things about it. I actually got told it was Comma oil re branded by ECP. Looking at the ECP website though it's only showing to be ÂŁ3 cheaper than the castrol oil, would the castrol not be a better buy at ÂŁ3 more and then it takes any doubts you may have away?
#12 ·
Blackbmw120d said:
I was told that Comma oil is Castrol made
" onclick="window.open(this.href);return false;? nav=item.view&id=390384161126
Triple X is carlube oil owned by chemical firm Terosyl they make oil for Asda, Tesco etc and also paint in aerosol cans, car shampoo and lots of other random cheap car items. I wouldn't put it in my car personally, not an oil brand snob, just conscious that its the only thing preventing metal to metal contact, and I want a good base oil and shear stability for as long as possible especially with turbo charged cars. Nothing fancy but most of the premium brand oils will give you this and possibly some piece of mind.
Comma is owned by Mobil which is Exxon Mobil and a subsidary, also Esso in the UK is owned by Mobil. Comma oil is pretty good and official partner to the FIA championship GP2, so while that doesn't make it the best it has considerable access to base oil and performance technology due to its parent company.
I have used it, and would do in the future.
Personally i don't like switching brands though, especially if a car is long running on one oil...
