681 - 700 of 1,207 Posts
Looking for some aftermarket wheels to my m140i, adaptive suspension with eibach pro kit.
Im thinking about just sticking to 18" wheels, is there any noticeable difference in ride quality compared to 19"?
Im utterly useless when it comes to right measurements on wheels so i feel i need some help haha.
Will i need spacers?
If going for 18", what measurements fits best, and i dont want any rubbing
And for 19?
That woud be for standard width tyres, 18" or 19".
I rarely recommend 235's, they're really big on diameter. 245's fit much better weirdly.
If you want to fit 255 rears you'll need rims at least 8.5" wide, with ET44+ ideally.
You've got it.
8.5" or 9" ET44 - ET50 for wider rears.
8" ET40 fronts will also take the standard 225mm front tyres, but they will be slightly stretched (minimal rim protection when parallel parking).
I need an expert opinion on these three sets of wheels for bmw
F20 116i sport with eibach sportline 40/40mm drop on stock suspension. Will any of these options fit, and what tyre dimensions should I go with? Spacers needed or not?
1) 18x8J ET38 (both front and rear)
2) 18x8.5J ET38 (both front and rear)
2) 19x8.5 ET35 (both front and rear)
Thanks in advance.
Thank you once again for the super fast reply marco. For stability and handling of the car, regarding the lower suspension, would you recommend square setup all around or different tyres in front and back? Which one would you do?
Hi guys,
I'm looking to buy some Bola fle/flc to my M140 xdrive.
I had a M135xi some years ago with the VMR710 19x8.5 et43 225/35 / 19x9.5 et50 255/30. Really liked the car with that setup, although I would have liked to had less stretch on the tyres.
But this time I'm thinking of going for 18", for more comfort.
1: What size and et would you go for, I was thinking 225/245 ps4?
2: Can you recommend a good place to buy from who ships to Sweden?
Thanks 😊
245 are smaller in diameter than 225, I'm not sure your xDrive system would like that difference in wheel speeds, long term?
Your previous 225 + 255 are a much better diameter match, or a square set-up such as 245 front and rear?
I have no idea who ships to Sweden, sorry.
Thanks for the reply marco_polo!
Ok. As I understand Bola supplies custom offset, what offset would you recommend for the same "Fit or poke" as my old vmr's?
marco_polo said:
Depends on which tyres you decide on?
ET40 fronts and ET45 rears would take most tyre sets quite nicely. But if you didn't want to go any wider than 245 rears you could go for ET40 square.
I saw that Bola fle are only available in 8x18, and I'm guessing 255 ps4 won't sit well on 8j?
For 225/255 am I right in thinking 8j/9j would be best?
Thanks for your help!
