641 - 660 of 1,207 Posts
I have a standard 2016 118i se and was wondering if the f30 400m wheels and stock tyres would fit without issues or would i need to change all the tyres to 40s in the front and 35s in the back? Standard rears are 255/40/18 and 225/45/18 front? Thanks
I'll need the last opinion from the experts:
Ultimate setup
8.0x18 ET 42 or 40? With option of 235/40 and 245/35
9.0x18 ET 50 or 52? With option of 255/35 and 265/35
A few people ran similar sizes on Koya wheels front ET40 and rear ET50, but I would like more room for the F8x I'm fitting on my car.
I think the rear should be fine but I'm more concerned about the fronts??
Which one should I go with?
marco_polo said:
8" ET40 and 9" ET50 will take 245/35 and 265/35
Thanks Marco as usual!
Shall I avoid the front 8.0ET45?
I'm contemplating between the poke difference for front and rear, and ET45 looks like a better choice. I saw some users with Bola 8.5Et40 which is more aggressive than 8.0Et45 in terms of distance from the strut?
But if you say so I'll totally get it. :eek: :eek:
Thanks again
marco_polo said:
You'll struggle to get a 245 on the front at ET45 as the tyre will rub on the strut. I'd go the correct ET40 every time, saves you having to buy 5mm non-concentric spacers and longer bolts.
Great! I didn't think about the bolts. :D
For the rear if go for 9.0ET50 will I need another set of bolts?
Hopefully the 265/35 Bridgestone will fit!
Hey!
So I was looking for a place on the internetz where I could get some nice info regarding wheels for my F20 and I think I have found one :) I went through this whole thread (took a while), got some ideas but just want to make sure it's ok.
First of all, the patient is 2015 LCI M135i with H&R springs (-25mm all around). Current set (with Michelin PS4):
- Front - 225/40/18 with OEM 7.5 / ET 45 (+10mm H&R spacers)
- Back - 245/35/18 with OEM 8.0 / ET 52 (+13mm H&R spacers)
Could go a bit more with the spacers, though it is my daily, I drive people around from time to time and I want to keep it safe with arches and stuff.
And I'm slowly thinking about switching wheels for 19inch, preferably without spacers.
Was thinking about those wheels: - they are in 2 widths - 8.5 and 9.5
- they offer custom ET on both sizes - ranging from 20 to 45
so I would like to confirm what the best choice would be :) for Micheli PS4S preferably
FRONT:
- I've seen that the proposed specs for 19x8.5 here were: 19x8.5 ET 35 with 235/35/19
- I don't mind if it "pokes" out a bit, but don't want it rubbing :)
- question is if a safer option would be 19x8.5 ET 40 to move the wheel a bit more inside - will that be ok with the struts and stuff?
REAR:
- this case is more complex, there are two options here: 8.5 again, and 9.5 (9.5 looks cool with that deep concave design)
- thing is that ET 45 is the highest value for both again
- 19x8.5 ET 45 with 255/30/19 seems safe choice from what I have read here (bit smaller ET maybe? 40? :F)
- but there is a temptation - what about 19x9.5 ET 45 with 255/30/19 tires? will they fit? I don't want to do any rolling and stuff, just want them to sit nicely like in the current setup I have
Thank you for your feedback!
M.
I'd be going:
Front: 19x8.5 ET 40 with 235/35/19 or 245/30/19
Rear: 19x8.5 ET 44 with 255/30/19
19x9.5" ET 45 with 255/30/19 should sort of fit, the wheels would be quite stanced though - you'd have to mind those kerbs. Here's an example of exactly how pokey they'd be:
Hey,
ok, so the 9.5 would stick out a lot, this won't do.
so would be going for:
thought that this would be, more or less, the perfect and safe fit :)
will try to find some pics of that setup maybe
The ACS wheels for our F20 in 18" are 8.5" and ET43
I'm very tempted by a set, on offer at ÂŁ999. What tyres would you run on these? 225/40 are an option but I'd like to go at least 235
However, before I take the plunge I wondered if there is anything better from the OEM range for around the same price? A used set of 405M 19s perhaps? But surely a new set is always preferable to used!
Aesthetics aside, are ACS well regarded, good quality kit?
Thanks Marco, I was hoping you'd reply!
My MPSS have about 5mm all round so I could use them. The chap at ACS suggested 225 40 all around, but it feels a bit skinny for 8.5.
I'll be moving to B16 suspension also.
225/40 is too skinny for an M-Lite summer rear, imo. 5mm is plenty of life, I'd pop those on for starters.
When they need replacing, have a measure up of the clearances. They should just be able to take 235/40 fronts matched to 255/35 rears, in theory.
