gear box oil and diff oil recommendations?
2.5K views 16 replies 6 participants last post by  stevesurrey
bmw 123d 2011 e82.
this is what opie said to me
Hi Martin
With Castrol, I would use the Syntrans B 75w in the gearbox and Syntrax Longlife 75w-90 for the diff.
With Red Line, I would use a 50/50 mix of their MTL and D4 ATF in the gearbox (the MTL is a little thick, the D4 is a little thin) and the 75w-90 GL5 in the diff.
The gearbox takes 1.6L and 1.2L for the diff.
Regards
Tim
#3 ·
Octavius said:
Redline is good to start with but breaks down quickly.
Just stay with the BMW OEM oils.
I learnt the hard way.
How did you learn the hard way if you don't mind me asking bud?
#4 ·
Where do you guys buy these oils from is opie the cheapest?
#5 ·
#7 ·
#8 ·
marco_polo said:
I usually buy my oils from eBay, Syntrans B 75w is about ÂŁ12 on there.
Marco do you agree with guy above saying get castrol instead redline as I have seen you recommend redline on past posts among the web?
#9 ·
#10 ·
Jay1er said:
Marco do you agree with guy above getting castrol instead redline as I have seen you recommend redline on past posts among the web?
Mine will be getting Redline shortly, but others prefer the Castrol.
#11 ·
Okay so would you agree with the guy that says "I would use a 50/50 mix of their MTL and D4 ATF in the gearbox (the MTL is a little thick, the D4 is a little thin) and the 75w-90 GL5 in the diff."
Or would you just use one or the other?
#13 ·
marco_polo said:
Sounds good to me, I'm going with a litre of MTL, then topping off with D4.
So 1 litre of MTL and the 0.6litres of D4? is there a reason for that instead of just 50/50 like the guy from opie said?
#15 ·
marco_polo said:
I just happen to like MTL, smooths out clunky changes a little, in my experience. Each to their own though. :)
So with mine being a 123d should I go for 50/50 of MTL and D4 basically half and hlaf like the guy said or 1 litre of MTL and 0.6 litres of D4 like you and your 135i?
#16 ·
Jay1er said:
should I go for 50/50 of MTL and D4 ... or 1 litre of MTL and 0.6 litres of D4
There's not going to be any perceptible difference between a 50/50 blend and a 60/40 blend. As long as you use appropriate oil from a decent brand, it will be fine. Most of the benefit comes from having "fresh oil". If you don't have a strong personal preference for one or another, just stick with BMW's recommended Castrol Syntrans B 75W. It's a very good oil.
#17 ·
