Coding - changed VO date MULF2 unit not shown
2.2K views 2 replies 1 participant last post by  rossonza
Hi All, i managed to code USB to my car yesterday, and also found out how to change the VO date.
I changed the VO date to #0407 (car says #1206 when read from the ecu).
Now i go through the options after changing the VO, but im still only seeing MULF and not MULF2, So when i try to read MULF i get a read error.
any ideas why mulf2 is not showing when i try to find the module to code bluetooth on?
Am i missing something obvious? - see attached screenshots
Ross.
#3 ·
sorted it.
didnt need to change the VO date.
set the $64L option. which in turn enabled the Mulf2 option under PROCESS ECU. i read the mulf2 module. found that bluetooth was nichtaktiv. changed to aktiv. coded to the car. and boom...... paired phone and tested a call.
so my pre 03/07 car did not require a vo change moving from a mulf to a mulf2 high basis svs. and it only cost me ÂŁ75.
next problem is. how do i enable speech control?
and also as soon as i code usb access. my aux no longer works. so i removed usb coding for now.
my understanding is the mulf2 unit has the aux capabilities rather than the current aux port plugging into my head unit.
so im trying to figure out how to enable usb. and move my aux cable from my headunit to the new mulf unit.
