Replacing ABS reluctor rings
1 reading
32K views 33 replies 8 participants last post by  teasdas
Morning all, had a few lights come on related to abs/dsc/traction control and code reader pointed to right rear wheel speed sensor. I've bought a new sensor but when I took the old one off notice it was scuffed and on closer inspection the reluctor ring has corroded and cracked. Ordered a pair of reluctor rings and I'm going to have a crack at replacing them myself so I have a couple of questions.
First, any tips to get the driveshaft bolts undone as they seemed completely solid when I had a go yesterday.
Second where can I buy replacement bolts on their own or am I ok to reuse if torqued correctly?
Sam
#7 ·
teasdas said:
marco_polo said:
You can get new BMW hub nuts from BMW.
I'm guessing you've read all this already, being a current thread?
Thanks Marco! Yeah I've seen that, is there a knack to getting the driveshaft bolts undone or just use a decent length breaker bar?
Did this last week, soaked the diff bolts in Plus Gas on a toothbrush the night before (both ends)and the 32mm spline end nut behind the wheel centre badge, I didn't remove the wheels to remove the shafts. Then gave them a tap with a pin hammer to break any seal. Didn't need a breaker bar, large ratchet sufficed. Just don't fit the new rings until the drive shaft ends are spotless. (Do the passenger side first, its much easier)
#10 ·
I had my local garage replace my passenger side abs ring and it ran me ÂŁ400 for parts and labour so if you can do it yourself you could save a penny or two. I will be doing it myself next time one goes!
#11 ·
teasdas said:
Managed to get all the bolts undone, hub but off, but I can't get the shaft free from the hub? Is there anything I can try without damaging any parts? If not it's booked in at the garage on Wednesday but I had hoped to save a few quid by doing it myself.
Plus Gas, lots and lots of Plus Gas.
Let it soak for hours to penetrate, then give it a whack with a plastic (or other soft) hammer
#12 ·
It's currently soaking in Plus Gas so I'll give it another go tomorrow, fingers crossed. If not I'll just have to fork out for garage fees [emoji30]
#13 ·
bloody hell ÂŁ400!
my local only charged me ÂŁ120 to swap it over and think it was about another ÂŁ50 in parts for a ring and padgid sensor.
#14 ·
Zambo said:
bloody hell ÂŁ400!
I'm hoping it will be closer to ÂŁ120, was that for one side or both? Surely on a ramp it shouldn't take longer than a couple of hours?
#15 ·
Yeah I was robbed and the idiots put the cable for the wheel speed sensor back on too tight so it kept unplugging itself :rollseyes:
#16 ·
teasdas said:
Zambo said:
bloody hell ÂŁ400!
it was just the one side, think it was a couple hours work for them to get it all done.
#17 ·
No luck getting the shaft out of the hub so it's off to the garage for them to have a look and see how much it will cost. If it's going to be a fortune I'm going to buy a universal hub puller and give that a go. My only concern if I get it out is will it go back in easy enough?
#20 ·
Garage had a look and said 9 out of 10 times the shaft is seized in the hub (dont I know it!) and i could be looking at 4 hours labour each side plus new bearings probably... to the tune of ÂŁ450! [emoji44]
So I've bought a hub puller and I'm hoping that will free the shaft!
Think it might be about time I bought an impact driver to save me a load of time!
#22 ·
Well finally got the driveshaft free from the hub this morning with a bit more punching. My wheel bolts weren't long enough for the hub puller of course! [emoji19] but hey it's out!
Here is the offending ring, cracked as you can see
So far no bearing damage so a very nice saving of ÂŁ450! Well happy. I think I'll leave the passenger side until it gives me a problem though [emoji23]
Thanks for all your useful info!
#24 ·
marco_polo said:
Good Man. :thumbs:
Thanks Marco, seems all is not well though as I'm still getting the orange traction control light on it's own with code CC-ID 35. Haven't had it hooked back up to code reader yet so could it just be the new sensor is faulty.
I haven't done the n/s yet so there's every chance it could be that side now.
Brakes seem better for some reason too but that may just be in my head [emoji848]
