120D Fuse box diagram
space
Post by space »
Im trying to locate a fault with a drivers side electric window, but my fuse box has no diagram! Cant belive BMW put it on a bit of paper that goes misssing. Can anyone tell me where I can get a diagram for the fuse box? of be kind enough to copy and paste theirs here. thanks
Re: 120D Fuse box diagram
Post by marco_polo »
I can't help you there, but I'd be surprised if each window got it's own fuse?
Are any fuses blown? I guess that would solve that line of elimination.
space
Post by space »
Due to the great location of the fuse box :roll: I would have to remove and check every fuse not knowing which one is windows, a diagram would save a lot of time and hassle
Smithy120d
Post by Smithy120d »
Fuse diagram as requested. Let us know how you get on plz.
Sydney Blue '55 120d Sport
DIY Modifications: Footwell & Puddle lights, EC rear view mirror, Heated seats, & a few bits of coding.
space
Post by space »
Thank you very much Smithy, looking at your image does that mean Fuses 21, 36, 41, 62, 64 are all Electric windows?
Post by Octavius »
space wrote:Thank you very much Smithy, looking at your image does that mean Fuses 21, 36, 41, 62, 64 are all Electric windows?
Yes it looks that way, the circuits are well protected.
space
Post by space »
Smithy I need to thank you again, a fuse was missing and drivers window is now working perfectly thanks to your image!
The rear passenger still only goes up in stages though?
Smithy120d
space wrote:Smithy I need to thank you again, a fuse was missing and drivers window is now working perfectly thanks to your image!
The window may have 'forgotten' its limits - to reset you need to lower the window and hold the switch for 5 seconds, then raise the window and hold for 5 seconds after it has shut.
space
Post by space »
GReat worked perfetly thank you once again
chinnyman
Post by chinnyman »
Would this fuse diagram be the same for a 56 plate 118d?
bmw_118d
Post by bmw_118d »
What is the number of rear view mirror photochromic fuse ? Thanks.
