Automatic Boot Spring Open
tahiblue
Post by tahiblue » Wed Mar 09, 2011 8:49 pm
Following on from this thread... http://www.babybmw.net/viewtopic.php?f=20&t=18057
* This is for informational purposes only, carry out any work at your own risk.
** I used 25mm Light Load springs with 3/4" tap washers.
*** I only wanted my boot to partially open, use different springs if you want the boot to fully open (http://www.babybmw.net/viewtopic.php?f= ... 7&start=85)
Gently push up on this clip and it slides out the top.
*** PROP UP THE BOOT LID ***
Simply pull the strut towards you and it will pop off the mount
Wrap and clamp both the shaft of the strut and the top. The shaft will need to be clamped tightly (ooh er missus).
Cloth removed to show you what it is to actually clamp. Turn anti-clockwise on the head to remove.
3/4" tap washers. They are a very tight fit!
Screw unto the thread.
Then brute force and push unto the shaft.
Slide on spring.
Refit head and pull washer and spring to the top.
Refit head to socket and replace the clip.
Stand back and push the button.
I'll probably take them off again and paint them black, maybe use a slightly smaller washer to make it look better.
135guy
Re: Automatic Boot Spring Open
Post by 135guy » Tue Apr 26, 2011 5:56 pm
Will the same springs in "option 5" be fine for the boot to pop open in an M sport coupe or would it be too powerful and hard to close?
E92 M3 Silverstone II
N54 135i M Sport, Performance pedals. Alpine upgrade kit, **SPAM** Glass Pro Sat Nav........SOLD
riske
Post by riske » Mon Sep 12, 2011 8:54 am
As above? What springs will work on m sport coupe?
Black 09 M Sport 120d Coupe
Alex N
Post by Alex N » Mon Sep 12, 2011 3:03 pm
Why they didn't design the boot to spring open when you press the keyfob button is beyond me! It is possibly the most annoying part of the ownership experience- when you have your hands full of shopping bags and have to wrestle the lid open or put the bags down to open the boot.
2007 116i ES, Titanium Silver
space
Post by space » Wed Sep 14, 2011 12:23 am
Where do you buy these springs?
Baldyloxxx
Post by Baldyloxxx » Fri Sep 23, 2011 2:57 pm
I echo the post above.
Where do you get these springs from and what exact dimentions are they?
Remember, theres no such thing as a stupid question..........
sonicvanman
Post by sonicvanman » Fri Sep 23, 2011 3:57 pm
I have thought about doing this mod but wasnt 100% on how to do it & where to get the parts & the correct parts from,
quality "how to" post, looks easy enough. thankx
But can any one post links to places we can buy the parts & for the different springs for half & full opening, so we know we're buying the rights parts.
cheers.
:chin: Or someone could buy the parts make a "how to" print it off put it together & sell it on ebay.
StayPuft
Post by StayPuft » Fri Sep 23, 2011 8:11 pm
sonicvanman wrote:I have thought about doing this mod but wasnt 100% on how to do it & where to get the parts & the correct parts from,
cheers.
I'm also in the same boat....u think the word is lazy! :-)
Any help appreciated!
sonicvanman
Post by sonicvanman » Tue Sep 27, 2011 5:50 pm
so i look through the other posts with the info & links & ordered my springs from Bearingboys
http://www.bearingboys.co.uk/V20x25_Lig ... ng-31026-p
& ordered the V20x25 light die spring as said on the post bellow
anit999 wrote:Image
so i've just fitted them & it only opens half way :?
could this be because my gas struts are worn as there 6 years old or i need a higher rigidity spring Or Anit999 lied?
im thinking i mite try the medium load springs B20x25mm @ rigidity 8.90 Or B20x32mm @ rigidity 7.00 as they should give i a bit more umf.
http://www.bearingboys.co.uk/B20x25_Med ... ng-31087-p
verysideways
Post by verysideways » Tue Sep 27, 2011 6:13 pm
If it opens half way then it's not the springs - the springs only open it the first foot or so. After that it's all about the gas struts really.
‘19 G01 X3 M40i on order
'18 F22 M240i (x2) - Thanks to TRL!
'16 F31 340i (going soon)
'16 F55 Cooper S
'13 F20 M135i
http://petrolhead.tours
sonicvanman
Post by sonicvanman » Tue Sep 27, 2011 6:15 pm
verysideways wrote:If it opens half way then it's not the springs - the springs only open it the first foot or so. After that it's all about the gas struts really.
so i'll need new struts then? there only £13 each
verysideways
Post by verysideways » Tue Sep 27, 2011 6:19 pm
Is that all? I should probably get a new pair myself then!
'16 F55 Cooper S
'13 F20 M135i
tahiblue
Post by tahiblue » Tue Sep 27, 2011 7:19 pm
Read through this post for more info on varying rates of spring length/size/rating success.
http://www.babybmw.net/viewtopic.php?f=20&t=18057" onclick="window.open(this.href);return false;
I bought my springs from bearing boys and the washers (3/4" flat tap washers) off amazon.
People have varying results with springs, but if you want it to really pop open I'd suggest going with a medium load 32mm spring (I do not take any responsibility if your car explodes as a result of fitting them).
sonicvanman
Post by sonicvanman » Thu Sep 29, 2011 6:19 pm
so job do, i had bought the correct springs & i need new gas struts as the old ones worn out & only opening half way.
so i brought 2x v20x25mm light load die springs @ £2.40 +vat each
from http://www.bearingboys.co.uk/V20x25_Lig ... ng-31026-p
very esay to fit as above & works a treat.
MrTracey
Post by MrTracey » Thu Sep 29, 2011 10:59 pm
sonicvanman wrote:so job do, i had bought the correct springs & i need new gas struts as the old ones worn out & only opening half way.
Can't watch your you-tube clip - says it's "private" (and I'm logged in to my forum account).
M135i F21/// Mineral Grey/Coral Red/Black MP grilles/Auto/Adaptive/HK
Return to “How To's”
