Don't bother cleaning the solenoids just replace them. £155 from cotswold. About a 30 min job.
Clear the codes and see if the heater one comes back.
I had them come on and cleaned them with abit of petrol and they've been fine since0l0dom0l0 said:By the way the vanos code is what will have turned your eml on.
No moving parts. Find the part number of it and Google it. You'll see what the look like. Soak in a cleaner of some kind.Italiandave said:Silly question but are there any moving parts which I will clean or is it just in one position until a current is passed through ??
Also would the eml go off or will I need to clear it
You'll need INPA. Where abouts are you?Italiandave said:Chickened out this morning... Too cold
Resetting adaptations ?
11367585425. You need two of those.Italiandave said:Hello
anybody got the aprt number for the solenoid?
friend of a friend works in the stealers.....
