I'm currently upgrading to LED interior lights and I am just wondering if these LED's will fit in the holder or are they to big? to fit through the hole
Cheers,
Cheers,
How bright are they. Any pics ?Sutt said:I can confirm they do fit!!!![]()
Not the best image. They're OK but not brilliant.Blackbmw120d said:How bright are they. Any pics ?Sutt said:I can confirm they do fit!!!![]()
Are these the same bulbs that are used in the dome lights then?0l0dom0l0 said:I've got them too. Very bright in the dome and map lights.
They fit the footwell too and look good.
Very happy with them the colour is perfect, almost an exact match to the OEM lights.
Go for it you won't be dissapointed.
Yes.Sutt said:Are these the same bulbs that are used in the dome lights then?0l0dom0l0 said:I've got them too. Very bright in the dome and map lights.
Are you talking about in the foot well or in general?SuperCNJ said:These aren't actually very bright. You should buy the ones that are flat, with all the LEDs facing right angles to the connectors. Also you may want to modify the housing of the footwell light. I removed a thin plastic "fin" inside to allow a longer LED bulb to fit.
Both. I don't find these LEDs bright at all and won't be bright in the footwell either.0l0dom0l0 said:Are you talking about in the foot well or in general?SuperCNJ said:These aren't actually very bright. You should buy the ones that are flat, with all the LEDs facing right angles to the connectors. Also you may want to modify the housing of the footwell light. I removed a thin plastic "fin" inside to allow a longer LED bulb to fit.
Because these are plenty bright enough.
