Correctdavidv111 said:It holds the wastegate fully open which has the effect of bypassing the turbo (as the turbo has no use when the wastegate is fully open)rob180bhp said:There is no way to bypass the turbo, it's an ecu running mode to warm the cats up for emissions test purposes
That's what I thought anyway
Or that's my understanding of it
Interesting and the reason for this is?DaleB90 said:Correctdavidv111 said:It holds the wastegate fully open which has the effect of bypassing the turbo (as the turbo has no use when the wastegate is fully open)rob180bhp said:There is no way to bypass the turbo, it's an ecu running mode to warm the cats up for emissions test purposes
Or that's my understanding of it![]()
The flap being closed is meant to create more back pressure and thus heat to help warm the cat up along with the wastegate being wide open and the exhaust gases bypassing the turbo and going straight to the cat.pitbull666 said:Interesting and the reason for this is?DaleB90 said:Correctdavidv111 said:It holds the wastegate fully open which has the effect of bypassing the turbo (as the turbo has no use when the wastegate is fully open)
And couldn't it be done and still have both exhaust pipes working?
The flap serves that purpose after cold start, but during cold start it's there to increase back pressure. The car is louder with the flap closed compared to open on cold start also.seanklein said:The exhaust gasses will pass through the cat regardless, the pipe work only separates at the back box?
The flap is there for noise control, usually vacuum operated under full throttle conditions(will open).
Manufacturers don't want loud Exhausts at cruising speeds or idle.
