Where are you located? Tyre probably OK, but will need changing at some point.
Lincoln area .Where are you located? Tyre probably OK, but will need changing at some point.
I’d avoid re cutting the wheel if possible as you can only do that so any times. . Wait for “really bad damage”. Go for. A smart repair first and see what you think.I have contacted my local dealer , they use a company next door to them , not sure if it’s part of the Soper dealership but they do all there wheel refurbs & bodywork repairs, they CNC machine the wheels and re diamond cut the rims , I will let them check the tyre at the same time .
As I said, when they paint the silver part, the reflections are such that you won’t notice painted / diamond cut parts. It’s only one part of the outer edge that will be painted and that will blend quite nicely.If that’s not really bad ?
How do they smart repair that type of finish so it matches.
Trust me, with that minimal damage, and given the wheel style, you won’t notice.I’m not sure about the smart repair but I will look into it , I can’t see how they match the diamond cut finish with paint .
