1 - 20 of 52 Posts
Here is the story:
I retrofitted OEM LCI Bi-Xenons NON AHL using this thread:
For the standing lights:
Pin1 on from headlights goes to pin 14 on X14260 (lower plug on FRM) and pin 41 on X14261 (upper plug on FRM)
For the Low beam
Pin 2 on the headlight goes to ground bonnet.
For high beam
pin5 from both headlight goes to pin 41 on on X14260 (lower plug FRM) - these two cables are joint together and go to one pin in FRM.
I also have FRM3 MAX Kuester installed.
I added $522 and flashed FRM with empty MAN file. I get angel eyes working, xenon works fine, welcome lights came online once I charged battery back.
All the harness is installed correctly so my idea is i have problem with coding. No matter what I try I cannot get the high beam to work.
When I want to flash with high beams the shutter of the right xenon opens AND BRAKE LIGHT COMES ON
When I brake along with brake light FRONT RIGHT XENON shutters open. Seems like braking signal goes to right xenon and vice versa when i flash the signal goes back to the stop light...
here is my TRC file. Any Ideas?
Code:
LENKWINKEL_UEBERSCHREITEN
	wert_01
LENKWINKEL_UNTERSCHREITEN
	wert_01
LENKSTOCK_UMSCHALT_VERZ
	wert_01
U_POTI_DIMM_MIN
	wert_01
U_POTI_DIMM_DELTA
	wert_01
MELDUNG_AENDERUNG_DIMMER
	wert_01
POTI_DIMM_INVERS
	aktiv
POTI_LWR_INVERS
	nicht_aktiv
HEIMLEUCHTEN
	wert_02
HEIMLEUCHTEN_ABBRUCH
	nicht_aktiv
HEIMLEUCHTEN_VERLAENG
	nicht_aktiv
AUTOM_LICHT_ABSCHALTUNG
	nicht_aktiv
WARNBLK_ENERGY_SAVE_MODE
	aktiv
ZUWACHS_TASTVERH_KL_58G
	wert_01
TASTVERH_BEL_WBL_MIN
	wert_01
	wert_02
ZUWACHS_TASTVERH_WBL_BEL
	wert_01
	wert_02
CBD_ZEICHN_INDEX
	wert_01
WERT_CRASHVERHALTEN
	wert_01
CRASH_WARNBLINKEN
	aktiv
CRASH_58G_EIN
	aktiv
TIPP_BLK_LOESCHT_IMMER
	aktiv
QUITT_BLK_ZU_CHECK
	aktiv
QUITT_BLK_SICHERN
	aktiv
QUITT_BLK_ENTSICHERN
	aktiv
NOTLAUF_FKT_GESCHW
	wert_01
NOTLAUF_FKT_TIMER
	wert_01
MIND_ANZ_ZYKL_TIPP_BLK
	wert_01
VIER_TUERER
	nicht_aktiv
AUTOM_LICHT_KONTROLLE
	nicht_aktiv
GETRIEBE_HANDSCHALTER
	aktiv
VORFELD_BEL_GEDIMMT
	aktiv
FL_UND_NSW_NICHT_GLEICHZ
	nicht_aktiv
ABSCHALTUNG_RFS
	nicht_aktiv
XENON_AL_VERBAUT
	aktiv
HALB/VOLLSCHRITT
	halbschritt
IB_2MIN_OPTION
	aktiv
IB_SOFTON_OPTION
	aktiv
LWR_ABS_MIN_STELLUNG_2
	wert_02
LWR_ANSTEUERN
	aktiv
LWR_FEHLER_BEWERTUNG
	wert_01
LWR_HYSTERESE_START
	wert_02
LWR_SCHRITTABSTAND_GRENZE
	wert_01
LWR_SCHRITTE_STELLUNG_0
	wert_01
LWR_SCHRITTE_STELLUNG_1
	wert_01
LWR_TEMPERATUR_GRENZE
	grad_-20
LWR_TESTBETRIEB
	nicht_aktiv
LWR_TREIBER_CODIERUNG_2
	wert_01
LWR_VORBESTROMUNG
	wert_02
SCHRITTABSTAND_STARTPHASE
	wert_01
U_LWR_POTI_STELLUNG_0
	wert_01
U_LWR_POTI_STELLUNG_1
	wert_01
U_LWR_POTI_STELLUNG_2
	wert_01
VERHALTEN_UEBERWACHUNG
	wert_01
XENON_LI
	wert_02
DEF_HEIMLEUCHTEN_CKM
	wert_02
DEF_QUITT_BLK_ENTSI_CKM
	aktiv
DEF_QUITT_BLK_SICH_CKM
	aktiv
DEF_ZYKL_TIPP_BLK_CKM
	wert_01
SICHERHEITS_FZG
	nicht_aktiv
AL_KL50_SCHUTZ
	nicht_aktiv
ALC_ERR_BLK_FREQ
	wert_01
ALC_FAHRZEUG
	nicht_aktiv
BFD_1_ALGORITHMUS
	aktiv
BFD_1_BLINK_FREQ_AUS
	wert_01
BFD_1_BLINK_FREQ_EIN
	wert_01
BFD_1_ENTPRELL_ABS
	wert_01
BFD_1_ENTPRELL_AX
	wert_01
BFD_1_MIN_GESCHW
	wert_01
BFD_1_STUFE_DELAY
	wert_01
BFD_1_THERM_TIMEOUT
	wert_01
BFD_1_WEGFALL
	nicht_aktiv
BFD_1_WERT_AX_EIN
	wert_01
BFD_1_WERT_AX_RUCK
	wert_01
HEIMLEUCHTEN_ENABLE
	aktiv
LOAD_DUMP_MAX_TIME
	wert_01
LOAD_DUMP_PRELL
	wert_03
NOTLAUF_FKT_SCHALTERSTELL
	aktiv
UMSCHALTOPT_LICHTSCHALTER
	wert_02
KL_VA_EIN_BEI_ENTRIEGELN
	nicht_aktiv
FH_CC_MELDUNGEN
	aktiv
QUITT_BLK_IGNORE_MOTORH
	aktiv
UNP_HEIMLEUCHTEN_CKM
	wert_02
UNP_QUITT_BLK_ENTSI_CKM
	aktiv
UNP_QUITT_BLK_SICH_CKM
	aktiv
UNP_ZYKL_TIPP_BLK_CKM
	wert_01
ABSCHW_D_TAU_HI
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
ABSCHW_D_TAU_LO
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
ABSCHWAECH_D_TAU
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
ABSTELLPOS_CUSTOM
	nicht_aktiv
ABSTELLPOS_SMC
	nicht_aktiv
AEND_V_SCHWENK_N_AUSSEN
	wert_09
	wert_13
	wert_14
	wert_15
	wert_21
	wert_22
	wert_23
	wert_24
ALC_ABSENKUNG_10_KM/H
	wert_09
ALC_ABTASTRATE_DYN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
ALC_ABTASTRATE_TREND
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
ALC_ABWEICHUNG_TREND
	wert_09
ALC_ANHEBUNG_175_KM/H
	wert_09
ALC_AUSWERT_GRADIENT
	aktiv
ALC_AUSWERT_PROP_ABWEICH
	aktiv
ALC_DAUER_DYN_NACHFUEHR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
ALC_DEF_LWR_SENSOR_HI
	wert_11
	wert_21
ALC_DIFFERENZ_MSP_DYN_STA
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
ALC_EINSCHALTBEDINGUNG
	wert_01
ALC_EPSILON_DELTA_A
	wert_13
	wert_14
	wert_19
ALC_EPSILON_DELTA_AV
	wert_18
	wert_19
ALC_GRADIENT_SCHLECHTWEG
	nicht_aktiv
ALC_HOEHENWEG
	wert_09
	wert_15
	wert_18
ALC_KENNLIN_LWR_SENSOR_HI
	wert_12
	wert_14
	wert_19
ALC_KENNLIN_LWR_SENSOR_VO
	wert_05
	wert_06
	wert_12
	wert_15
	wert_16
	wert_25
ALC_KLS_ENABLE
	nicht_aktiv
ALC_LWR_NEIGUNG_KONSTANTE
	wert_09
ALC_LWR_VORZEICHEN
	nicht_aktiv
ALC_MIN_STEIGUNG_VZ_WECHS
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
ALC_MINDESTANZAHL_VZ_WECH
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_12
	wert_13
	wert_14
	wert_15
	wert_18
ALC_MITTELUNGSINT_VZ_WECH
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
ALC_MITTELUNGSINTERV_DYN
	wert_09
ALC_MITTELUNGSINTERV_TREN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
ALC_NACHLAUF_SCHLECHTWEG
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
ALC_OFFSET_LWR
	wert_29
ALC_SAETT_TIMER_SCHLECHTW
	aktiv
ALC_SCHW_GRAD_BESCHLEUNIG
	wert_01
	wert_04
	wert_07
	wert_19
ALC_SCHW_GRAD_BREMSEN
	wert_01
	wert_04
	wert_07
	wert_19
ALC_SCHW_GRAD_SCHLECHTWEG
	wert_01
ALC_SCHW_PROP_ABWEICHUNG
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_16
	wert_17
	wert_18
	wert_21
ALC_SCHW_TREND
	wert_09
ALC_SCHWENK_LATCH
	aktiv
ALC_VMAX_BESCHLEUNIGUNG
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
ALC_VMAX_BREMSEN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
ALC_VMIN_BESCHLEUNIGUNG
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_18
ALC_VMIN_BREMSEN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_18
AUTO_LWR_ENABLE
	aktiv
BLEND_CHECK_IST_WINKEL
	aktiv
BLEND_CHECK_SOLL_WINKEL
	nicht_aktiv
C_METER_NACH_INNEN_HI
	wert_09
CAN_11H
	nicht_aktiv
CHECK_FGN_SMC_ALC_OFF
	aktiv
CHECK_SMC_ERROR
	aktiv
CKM_ALC
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
CKM_ALC_DEF
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
D_TAU_MITTEL_GIERR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
D_TAU_MITTEL_LENKW
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
DRIFT_DEKR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
DRIFT_INKR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
DRIFT_SCHWELLE
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
DYNAM_LWR_ENABLE
	aktiv
ERR_LWR_L_IGNORIEREN
	nicht_aktiv
ERR_LWR_R_IGNORIEREN
	nicht_aktiv
ERR_SCHWENK_L_IGNORIEREN
	nicht_aktiv
ERR_SCHWENK_R_IGNORIEREN
	nicht_aktiv
FZG_RADSTAND
	wert_09
IK_BUS_TEILNEMER
	nicht_aktiv
KEINE_L_R_SYNCHRONISATION
	nicht_aktiv
KENNL_MAX_UEBERST
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
KENNL_REDUZ_MAX_SCHWENK
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
KLASSIF_DRIFT_ENA
	aktiv
KLASSIF_LENKM_ENA
	aktiv
KLASSIF_UEBERST_ENA
	aktiv
KLS_BEI_AL_AKTIV
	nicht_aktiv
LENK_UEBERSETZUNG
	wert_13
	wert_14
	wert_16
	wert_17
	wert_18
	wert_22
	wert_27
LENK_UEBERSETZUNG_LO
	wert_13
LICHTZ_R_L_FAKTOR
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_12
	wert_13
	wert_14
	wert_15
	wert_17
	wert_18
	wert_19
	wert_20
	wert_21
LINKSVERKEHR
	nicht_aktiv
LWR_ABSTELLPOS
	wert_01
MAX_DELTA_KEINE_VERR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
MAX_SW_SCHWENK_V_HORIZ
	wert_05
	wert_06
	wert_09
	wert_13
	wert_14
	wert_15
	wert_17
	wert_18
	wert_19
	wert_20
	wert_21
	wert_22
MAX_SW_SCHWENK_V_VERTI
	wert_05
	wert_06
	wert_09
	wert_10
	wert_12
MAX_SW_SCHWENK_W_AUSSEN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_10
	wert_12
	wert_14
	wert_15
	wert_16
	wert_18
	wert_19
	wert_20
	wert_21
	wert_22
MAX_SW_SCHWENK_W_INNEN
	wert_05
	wert_06
	wert_09
	wert_13
	wert_14
	wert_15
	wert_18
MAX_VERRINGERUNG_V_SCHW
	wert_09
MERKM_1_BEGR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
MERKM_1_DEKR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
MERKM_1_INKR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
MERKM_1_MAX
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
MIN_DELTA_MAX_VERR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
MIN_SW_SCHWENK_V_HORIZ
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
MIN_SW_SCHWENK_V_VERTI
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
NORM_LEUCHTWEITE
	wert_09
OHNE_GIERRATE
	nicht_aktiv
RAUSCH
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
RECHTSVERKEHR
	aktiv
REDUZIERUNG_V_SCHWENK_HI
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
REDUZIERUNG_V_SCHWENK_LO
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
SCHALTER_R_GANG
	nicht_aktiv
SCHW_TAU_LW_GR
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
SW_NULL_BEREICH
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
T_F_GIERRATE_DEF
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
T_FILTER_DYN_LZ
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
T_FILTER_GIERRATE
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
T_FILTER_LENKWINKEL
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
T_FILTER_TAU_LW
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
T_FILTER_UEBERST
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
T_FILTER_V_VEH
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
TAU_ABSCHWAECHUNG
	wert_09
	wert_10
	wert_12
	wert_13
	wert_14
V_HI_ABSCHW_D_TAU
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_AENDER_LENK_UEBERS
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_RED_SCHWENK_W
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_REDUZIER_V_SCHWENK
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_SW_MITLENKEN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_SW_NACH_INNEN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_TAU_GIERRATE
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_ABSCHW_D_TAU
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_AENDER_LENK_UEBERS
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_RED_SCHWENK_W
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_REDUZIER_V_SCHWENK
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_20
	wert_21
V_LO_SW_MITLENKEN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_SW_NACH_INNEN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_TAU_GIERRATE
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_M_HI_REDUZIER_V_SCHWENK
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
	wert_26
	wert_27
V_M_LO_REDUZIER_V_SCHWENK
	wert_09
	wert_10
	wert_12
	wert_13
	wert_14
	wert_17
	wert_18
	wert_26
	wert_27
V_REFERENZLAUF_EN
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
WINKEL_BLENDUNG
	wert_02
ZEITK_TRIGGER1
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
KURZSCHL_WIERHOL_ZAEHLER
	wert_01
KURZSCHLUSS_CHECK_TIME
	wert_01
KURZSCHLUSS_ENTPRELL
	wert_01
NACHLAUF_KLEMME_VA
	wert_01
ASP_KEY_MEM_OHNE_MASTER
	aktiv
LWR_DIAG_PARAM
	wert_02
LWR_HEBEL
	wert_01
ZUWACHS_TASTVERH_FLC_LED
	wert_01
	wert_02
FSP_ISP_SPERREN
	wert_03
ASP_LIN_VERBAUT
	nicht_aktiv
ALC_DISABLE_AUSGL_NICK_GW
	aktiv
IBUS_R_GANG
	nicht_aktiv
GB_DELTA_POS
	wert_01
GB_POS_AUS
	wert_01
GB_T_EINFAHREN
	wert_01
GB_T_NOTLAUF
	wert_01
GB_USE_SBE
	nicht_aktiv
ABK_KNICK
	wert_01
ABK_MIN_PROZ
	wert_01
ABK_VERLAENG
	wert_01
ABSCHW_D_TAU_HI_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
ABSCHW_D_TAU_LO_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
ABSCHWAECH_D_TAU_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
AEND_V_SCHWENK_N_AUSSE_SP
	wert_05
	wert_06
	wert_09
	wert_10
	wert_12
	wert_13
	wert_14
	wert_17
	wert_18
	wert_19
	wert_20
EINLENKEN_RKW
	aktiv
ENTGEGENGES_RKW
	aktiv
FL_ASSIST_CC_NOT_AKTIV
	aktiv
FL_ASSIST_FUNKTIONS_ANZ
	nicht_aktiv
FL_ASSIST_ZUST_22_32
	nicht_aktiv
FL_AUS_BEI_BIX_IN_S_FLC
	nicht_aktiv
GB_TRIGGER_KL_15
	nicht_aktiv
GB_TRIGGER_KL_R
	nicht_aktiv
HEIZ_ANF
	wert_01
HEIZ_KNICK
	wert_01
KENNL_MAX_UEBERST_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
KENNL_REDUZ_MAX_SCHWEN_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
LENK_UEBERSETZUNG_LO_SP
	wert_13
MAX_DELTA_KEINE_VERR_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
MAX_HEIZZEIT
	wert_01
	wert_03
	wert_04
	wert_05
	wert_06
	wert_07
MAX_VERRINGERUNG_V_SCH_SP
	wert_09
	wert_13
	wert_14
	wert_15
	wert_17
	wert_18
MIN_DELTA_MAX_VERR_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
MIN_SW_SCHWENK_V_HORIZ_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
NACHL_RKW
	wert_01
NO_BLK_RKW
	nicht_aktiv
RAMPE_AUS_BLK
	wert_01
RAMPE_AUS_KRV
	wert_01
RAMPE_AUS_RUE
	wert_01
RAMPE_EIN_BLK
	wert_01
RAMPE_EIN_KRV
	wert_01
RAMPE_EIN_RUE
	wert_01
REDUZIERUNG_V_SCHWE_HI_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
REDUZIERUNG_V_SCHWE_LO_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
START_ABBL
	wert_01
SW_NULL_BEREICH_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
T_FILTER_UEBERST_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
T_FILTER_V_VEH_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
TAU_ABSCHWAECHUNG_SP
	wert_09
	wert_10
	wert_12
	wert_13
	wert_14
V_E_HI_BLK
	wert_01
V_E_HI_KRV
	wert_01
	wert_04
	wert_07
	wert_09
	wert_11
V_E_LO_BLK
	wert_01
V_E_LO_KRV
	wert_01
	wert_04
	wert_07
	wert_09
	wert_11
V_HI_ABSCHW_D_TAU_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_AENDER_LENK_UEBER_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_RED_SCHWENK_W_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_REDUZIER_V_SCHWEN_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_SW_MITLENKEN_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_HI_SW_NACH_INNEN_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_ABSCHW_D_TAU_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_AENDER_LENK_UEBER_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_RED_SCHWENK_W_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_REDUZIER_V_SCHWEN_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_SW_MITLENKEN_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_LO_SW_NACH_INNEN_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_M_HI_REDUZIER_V_SCHW_SP
	wert_01
	wert_04
	wert_05
	wert_06
	wert_07
	wert_09
	wert_10
	wert_11
	wert_12
	wert_13
	wert_14
	wert_15
	wert_16
	wert_17
V_M_LO_REDUZIER_V_SCHW_SP
	wert_09
	wert_10
	wert_12
	wert_13
	wert_14
	wert_17
	wert_18
V_S_HI_BLK
	wert_01
V_S_HI_KRV
	wert_01
V_S_LO_BLK
	wert_01
V_S_LO_KRV
	wert_01
WELCOME_LIGHT_ACTIVE
	aktiv
WL_AL
	nicht_aktiv
WL_DAUER
	wert_01
WL_FL
	nicht_aktiv
WL_MAX_DAUER
	wert_01
WL_NSL
	nicht_aktiv
WL_NSW
	nicht_aktiv
WL_SL_1
	soft_einschalten
SL_ABSCH_OHNE_ECE
	aktiv
GB_CA_FAHRZEUG
	nicht_aktiv
ABBIEGELICHT_CKM_0
	nicht_aktiv
ABBIEGELICHT_CKM_1
	nicht_aktiv
ABBIEGELICHT_CKM_2
	nicht_aktiv
ABBIEGELICHT_CKM_3
	nicht_aktiv
AHL_MODE_CKM_0
	wert_01
AHL_MODE_CKM_1
	wert_01
AHL_MODE_CKM_2
	wert_01
AHL_MODE_CKM_3
	wert_01
ALC_ERR_BLK_AL_EIN
	aktiv
ALC_ERR_NSW_ZUSCHALTEN
	aktiv
ALC_FAILSAVE
	nicht_aktiv
ALC_SCHWENK_IM_STAND
	aktiv
ALC_ZUSTANDS_AUTOM
	wert_02
BFD_1_MIT_BFD
	wert_01
BFD_1_MIT_BL_M
	wert_01
BFD_1_MIT_NSL
	wert_01
BLK_TIMER_STAND
	wert_01
BREMSL_FKT_MIT_BFD
	aktiv
CC_MELDUNG_KL_58G
	wert_01
DEF_ABBIEGELICHT_CKM
	nicht_aktiv
DEF_AHL_MODE_CKM
	wert_01
DEF_SMART_BEAM_CKM
	nicht_aktiv
DEF_WELCOMELIGHT_CKM
	aktiv
DOPPELBLINKIMPULS_CRASH
	nicht_aktiv
DOPPELBLINKIMPULS_WARNBLK
	nicht_aktiv
FL_ASSIST_ENABLE
	nicht_aktiv
H_SENSOREN_UEBER_FCAN
	nicht_aktiv
HEIMLEUCHTEN_1
	wert_02
HEIMLEUCHTEN_2
	wert_02
HEIMLEUCHTEN_3
	wert_02
HYST_STAND_KRV
	wert_01
MAX_SCHWENK_V_H_BEGR
	wert_09
	wert_15
	wert_17
	wert_18
	wert_19
	wert_20
	wert_21
MAX_SCHWENK_V_H_BEGR_SP
	wert_05
	wert_06
	wert_09
	wert_21
MIND_ANZ_ZYKL_TIPP_BLK_1
	wert_01
MIND_ANZ_ZYKL_TIPP_BLK_2
	wert_01
MIND_ANZ_ZYKL_TIPP_BLK_3
	wert_01
NEUE_FAHRT_KL_15_NACHL
	wert_01
NEUE_FAHRT_OPTION
	aktiv
NSL_EINSEITIG_VERBAUT
	nicht_aktiv
PWM_AL
	wert_01
PWM_FL
	wert_02
PWM_FL_BEI_BIXENON
	wert_01
PWM_IB
	wert_01
PWM_NSL
	wert_05
PWM_NSL_FKT_SL
	wert_01
PWM_RFS
	wert_05
PWM_VFB
	wert_01
QUITT_BLK_ENTSICHERN_1
	aktiv
QUITT_BLK_ENTSICHERN_2
	aktiv
QUITT_BLK_ENTSICHERN_3
	aktiv
QUITT_BLK_SICHERN_1
	aktiv
QUITT_BLK_SICHERN_2
	aktiv
QUITT_BLK_SICHERN_3
	aktiv
SMART_BEAM_CKM_0
	nicht_aktiv
SMART_BEAM_CKM_1
	nicht_aktiv
SMART_BEAM_CKM_2
	nicht_aktiv
SMART_BEAM_CKM_3
	nicht_aktiv
TAGFAHRLICHT_ECE_1
	aktiv
TAGFAHRLICHT_ECE_2
	aktiv
TAGFAHRLICHT_ECE_3
	aktiv
U_MIN_TK_SNU
	wert_01
UNP_ABBIEGELICHT_CKM
	nicht_aktiv
UNP_AHL_MODE_CKM
	wert_01
UNP_SMART_BEAM_CKM
	nicht_aktiv
UNP_WELCOMELIGHT_CKM
	aktiv
WELCOMELIGHT_CKM_0
	aktiv
WELCOMELIGHT_CKM_1
	aktiv
WELCOMELIGHT_CKM_2
	aktiv
WELCOMELIGHT_CKM_3
	aktiv
CC_MELD_SW_CI_NOT_AKTIV
	aktiv
CODIERINDEX_FRM
	wert_01
FH_CONT_MAUT_NACH_KL50
	aktiv
FH_LANGHUB
	wert_03
TIMEOUT_SET_DTC
	aktiv
GB_ENTPRELL_TRIGGER
	wert_01
GB_QUICKSTART
	nicht_aktiv
MAX_BETAETIGUNG_FOMEHO
	wert_02
WL_ZYKLEN
	wert_01
ALC_PARAMETER_FAILSAVE_1
	wert_01
ALC_PARAMETER_FAILSAVE_2
	wert_01
CC_MELD_LICHT_AN_WARNUNG
	aktiv
DUAL_SP_LAMPEN_ARRAY_1
	wert_07
	wert_14
DUAL_SP_PARAMETER_2
	wert_01
DUAL_SP_PARAMETER_3
	wert_01
KURZSCHLUSS_CHECK_DISABLE
	wert_01
	wert_02
OFFSET_ADC_SNU
	wert_01
OFFSET_ADC_TK
	wert_01
RECHTS_LENKER
	nicht_aktiv
ABBL_LZ_RKW
	wert_01
ABBL_LZ_STAND
	wert_01
ENDE_ABBL
	wert_01
	wert_04
HYST_RKW
	wert_01
LH_UND_NSW_NICHT_GLEICHZ
	nicht_aktiv
TIPP_BLK
	nicht_aktiv
VORH_HEIZZ
	wert_01
GB_FAILSAFE
	wert_01
GB_NAD
	wert_01
BEHOERDE_FL_ASYNCHRON
	nicht_aktiv
BEHOERDENFAHRZEUG
	nicht_aktiv
BL_SCHALTLOGIK_E92_93
	aktiv
DRL_TFL_MIT_BLK_V_GED
	nicht_aktiv
DRL_TFL_MIT_KZL
	nicht_aktiv
ENERGIE_UBATT_LIMIT
	wert_01
ENERGIE_ZEIT_ENTPRELL
	wert_01
ENERGIE_ZEIT_LIMIT
	wert_01
LOAD_DUMP_DIMM_AL
	nicht_aktiv
LOAD_DUMP_DIMM_BL
	aktiv
NSL_AUS_BEI_FE_MODE
	nicht_aktiv
SL_SCHALT_UMSCHALT_OPT
	wert_02
WARNBLK_ENERGY_SAVE_AHM
	aktiv
ABBIEGELI_AUS_BEI_FL_LH
	aktiv
ALC_IMMER_BEI_S_FLC
	nicht_aktiv
ALC_NSW_NEU_ANF
	aktiv
ENABLE_GURTBRINGER_BF
	nicht_aktiv
ENABLE_GURTBRINGER_FA
	nicht_aktiv
GB_ENTPRELL_CAN
	wert_01
GB_V_MAX_KMH
	wert_01
LWR_MAX_POS_NORM
	wert_01
LWR_MAX_POS_REF
	wert_01
LWR_OFFSET_PLATTLAUF_L
	wert_01
LWR_OFFSET_PLATTLAUF_R
	wert_01
BFD_GESPERRT_BEI_NSL
	aktiv
SIGNALBILD_SL
	sl_1_und_sl_2
SL_PARKL_ABSCH_12H
	aktiv
ZEIT_PARKL_AKTIVIERUNG
	wert_01
DRL_TFL_MIT_NSW
	nicht_aktiv
TAGFAHRLICHT_ECE_0
	aktiv
DEF_TAGFAHRLICHT_ECE_CKM1
	aktiv
GB_ANZ_REVERSIEREN
	wert_01
GB_T_REVERSIEREN
	wert_01
UNP_TAGFAHRLICHT_ECE_CKM1
	aktiv
AG_M_ALWR
	wert_01
AHL2_ENABLE
	nicht_aktiv
ALWR_ENABLE
	nicht_aktiv
C1_HORI_BF
	wert_01
C1_HORI_FA
	wert_01
C1_VERT_BF
	wert_01
C1_VERT_FA
	wert_01
	wert_03
	wert_06
	wert_07
	wert_08
	wert_09
	wert_10
C2_HORI_BF
	wert_01
C2_HORI_FA
	wert_01
C2_VERT_BF
	wert_01
C2_VERT_FA
	wert_01
	wert_03
	wert_06
	wert_07
	wert_08
	wert_09
	wert_10
E__HORI_BF
	wert_01
E__HORI_FA
	wert_01
	wert_02
	wert_03
	wert_05
	wert_07
	wert_08
	wert_11
E__VERT_BF
	wert_01
	wert_06
E__VERT_FA
	wert_01
	wert_02
	wert_03
	wert_05
	wert_06
	wert_07
	wert_08
	wert_09
	wert_10
	wert_11
E3_HORI_BF
	wert_01
E3_HORI_FA
	wert_01
	wert_06
E3_VERT_BF
	wert_01
E3_VERT_FA
	wert_01
F_A_ALWR
	wert_01
F_ALWR
	wert_01
F_SWEG_ALWR
	wert_01
GL_ALWR
	wert_01
LWR_DIAG_COOL_TIME
	wert_01
LWR_DIAG_HEAT_TIME
	wert_01
MAX_KRUEMM
	wert_01
NSW_AUTOBAHN
	wert_02
OFFSET_GESCHW
	wert_02
R_SWEG_ALWR
	wert_01
REF_DEMO
	wert_01
	wert_07
	wert_08
	wert_17
	wert_18
	wert_19
	wert_20
	wert_21
	wert_22
STRST_MAXDIFF_ALWR
	wert_01
T_ALWR_AM
	wert_01
T_ALWR_AUS
	wert_01
T_ALWR_MKR
	wert_01
T_ALWR_NST
	wert_01
T_ALWR_SW
	wert_01
V__HORI_BF
	wert_01
V__HORI_FA
	wert_01
V__VERT_BF
	wert_01
V__VERT_FA
	wert_01
	wert_03
	wert_06
	wert_07
	wert_08
	wert_09
	wert_10
V_ALWR_AM
	wert_01
V_ALWR_AN
	wert_01
V_ALWR_AUS
	wert_01
V_ALWR_BAB1
	wert_01
V_ALWR_BAB2
	wert_01
V_HI_AUTOB
	wert_01
V_HI_STADT
	wert_01
V_LO_AUTOB
	wert_01
V_LO_STADT
	wert_01
V_MID_LANDSTR
	wert_01
V_MIN_KRUEMM
	wert_01
V_NSW
	wert_01
VERZ_REF_DEMO
	wert_01
	wert_02
W_ALWR_EKR
	wert_01
W_ALWR_MKR
	wert_01
W_ALWR_SW
	wert_01
WEG_GERADE
	wert_01
Z_ALWR_NST
	wert_01
Z_ALWR_SW
	wert_01
ZEIT_AUTOB
	wert_01
BFD2_A_LOE
	wert_02
BFD2_A_MIN
	wert_01
BFD2_AKTIV
	nicht_aktiv
BFD2_BFD
	nicht_aktiv
BFD2_BL
	nicht_aktiv
BFD2_BL_M
	blinkend
BFD2_BLINKEN
	3_hz
BFD2_ESS_ANZEIGE
	nicht_aktiv
BFD2_ESS_ENABLE
	nicht_aktiv
BFD2_NSL
	nicht_aktiv
BFD2_T_ABS
	wert_01
BFD2_V_MIN
	wert_01
WBLG_A_ABS
	wert_02
WBLG_A_ANF
	wert_02
WBLG_F
	wert_01
WBLG_G_MIN
	wert_01
WBLG_N
	wert_01
WBLG_T_L_MIN
	wert_01
WBLG_V_WBL
	wert_01
WBLG_WBL_ENABLE
	nicht_aktiv
LED_BLINKER_HINTEN
	nicht_aktiv
LED_BLINKER_VORNE
	nicht_aktiv
OPEN_LOAD_LED_BLINKER_H
	wert_01
OPEN_LOAD_LED_BLINKER_V
	wert_01
SM_FKT_ZUSATZBLINKER
	nicht_aktiv
DRL_TFL_MIT_BFD
	nicht_aktiv
HECKKL_SL_LOGIK
	nicht_aktiv
PWM_BFD_FKT_SL
	wert_01
WL_BFD
	nicht_aktiv
ADAPTION_CAN_LWR_LWS
	f_can
ASP_BORDSTEIN_AUTOM
	nicht_aktiv
ASP_EINKLAPPEN
	nicht_aktiv
ASP_ELEKTROCHROM
	nicht_aktiv
ASP_GESCHW_AUTO_AUSKLAPP
	wert_01
ASP_HEIZUNG
	nicht_aktiv
ASP_KOMFORT_EINKLAPP
	nicht_aktiv
ASP_MAX_GESCHW_EINKLAPPEN
	wert_01
ASP_MEMORY
	nicht_aktiv
ASP_NO_SPIEGEL_LIN_START
	nicht_aktiv
ASP_WEG_BORDSTEIN_AUTOM
	wert_01
BFD_1_MIT_BL
	wert_01
BFD_1_MIT_SL_1
	wert_00
BFD_1_MIT_SL_2
	wert_00
BFD_ERSETZT_BL
	nicht_aktiv
BFD_ERSETZT_SL_1
	nicht_aktiv
BFD2_SL_1
	nicht_aktiv
BFD2_SL_2
	nicht_aktiv
BL_ERSETZT_SL_1
	nicht_aktiv
BL_ERSETZT_SL_2
	nicht_aktiv
BREMSL_FKT_MIT_BL
	aktiv
BREMSL_FKT_MIT_NSL
	nicht_aktiv
BREMSL_FKT_MIT_SL_1
	nicht_aktiv
BREMSL_FKT_MIT_SL_2
	nicht_aktiv
DRL_TFL_MIT_BL
	nicht_aktiv
DRL_TFL_MIT_SL_1
	aktiv
DRL_TFL_MIT_SL_2
	aktiv
FH_COUPETUER
	aktiv
FH_KURZHUB_DISABLE_FEMOD
	aktiv
FH_KURZHUBDELAY_ZU
	wert_01
FH_LIN_BEDIENBLOCK
	nicht_aktiv
FH_MAN_MIT_EKS
	aktiv
FH_MAUT_AUF_BFT_ENABLE
	aktiv
FH_MAUT_AUF_FAT_ENABLE
	aktiv
FH_MAUT_ZU_BFT_ENABLE
	aktiv
FH_MAUT_ZU_FAT_ENABLE
	aktiv
FH_PANIKMODUS
	aktiv
FH_PANIKMODUS_MIT_EKS
	aktiv
FH_TIME_WAIT_ST_WRG_ENB
	wert_01
FH_US_REVERSE
	nicht_aktiv
FH_WAIT_ST_WRG_ENB
	nicht_aktiv
FSP_LAMPEN_MASK_FRM3
	wert_01
FSP_MASKIERUNG_FRM3
	wert_01
HEIMLEUCHTEN_FUNKSCHL
	nicht_aktiv
ISP_MASKIERUNG_FRM3
	wert_01
KALTUE_AL_M1_6_M2_38
	nicht_aktiv
KALTUE_BFD_M1_5_M1_37
	aktiv
KALTUE_BL_M2_43_M2_9
	aktiv
KALTUE_BLM_M1_40
	nicht_aktiv
KALTUE_FRA_H_M2_45_M1_12
	aktiv
KALTUE_FRA_V_M1_13_M2_40
	aktiv
KALTUE_KZL_M2_49
	nicht_aktiv
KALTUE_NSL_M2_51_M1_10
	aktiv
KALTUE_NSW_M2_37_M1_3
	aktiv
KALTUE_POL_M2_50_M1_8
	nicht_aktiv
KALTUE_RFS_M2_47_M1_9
	aktiv
KALTUE_SL_1_M1_14_M2_41
	aktiv
KALTUE_SL_2_M1_16_M1_18
	nicht_aktiv
LEUCHTDICHTE_EXPONENTIEL
	nicht_aktiv
LOAD_DUMP_ABSCHALT_FL
	nicht_aktiv
LOAD_DUMP_ABSCHALT_KL58G
	aktiv
LOAD_DUMP_ABSCHALT_KZL
	aktiv
LOAD_DUMP_ABSCHALT_NSL
	aktiv
LOAD_DUMP_ABSCHALT_NSW
	aktiv
LOAD_DUMP_ABSCHALT_RFS
	aktiv
LOAD_DUMP_ABSCHALT_SL_1
	nicht_aktiv
LOAD_DUMP_ABSCHALT_SL_2
	nicht_aktiv
LOAD_DUMP_DIMM_WERT_KL58G
	wert_01
LOAD_DUMP_SCHUTZ
	nicht_aktiv
LWR_DIAG_PARAM_A
	wert_01
MIN_TASTVERH_BEL_FLC_LED
	wert_01
MIN_TASTVERH_KL_58G
	wert_01
NSL_ERSETZT_BL
	nicht_aktiv
NSL_ERSETZT_SL_1
	nicht_aktiv
OPTIONEN_SL_ABSCH_TFL_FL
	aktiv
PARKL_FKT_MIT_BL
	nicht_aktiv
PARKL_FKT_MIT_NSW
	nicht_aktiv
PARKL_FKT_MIT_POL
	nicht_aktiv
PARKL_FKT_MIT_SL_1
	aktiv
PARKL_FKT_MIT_SL_2
	aktiv
PWM_BFD_ERSETZT_SL_1
	wert_01
PWM_BL_FKT_BL
	wert_07
PWM_BL_FKT_SL
	wert_01
PWM_BL_M
	wert_01
PWM_FL_NSW_FKT_ABBLIEGEL
	wert_03
PWM_NSL_FKT_BFD
	wert_06
PWM_NSW_FKT_PARKL
	wert_01
PWM_NSW_FKT_TFL
	wert_01
PWM_POL
	wert_04
PWM_POL_BEI_AKTIVEN_AL
	wert_04
PWM_POL_BEI_AKTIVEN_FL
	wert_04
PWM_SL_1_FKT_BL_TFL
	wert_03
	wert_09
PWM_SL_1_FKT_PARKL
	wert_04
	wert_10
PWM_SL_1_FKT_SL_TFL
	wert_04
	wert_10
PWM_SL_2_FKT_BL
	wert_04
PWM_SL_2_FKT_SL
	wert_03
SL_FKT_MIT_BL
	nicht_aktiv
SL_FKT_MIT_NSW
	nicht_aktiv
SL_FKT_MIT_POL
	nicht_aktiv
SL_FKT_MIT_SL_1
	aktiv
SL_FKT_MIT_SL_2
	aktiv
TIPP_BLK_ABBR_GEGENRICHT
	aktiv
TIPP_BLK_ABBR_GLEICHRICHT
	aktiv
VERBAU_H_SENSOR_VORNE
	links
WARMUE_AL_M1_6_M2_38
	aktiv
WARMUE_BFD_M1_5_M1_37
	aktiv
WARMUE_BL_M2_43_M2_9
	aktiv
WARMUE_BLM_M1_40
	nicht_aktiv
WARMUE_FRA_H_M2_45_M1_12
	aktiv
WARMUE_FRA_V_M1_13_M2_40
	aktiv
WARMUE_IB_M1_35
	nicht_aktiv
WARMUE_KL_58G_M2_48
	nicht_aktiv
WARMUE_KZL_M2_49
	nicht_aktiv
WARMUE_NSL_M2_51_M1_10
	aktiv
WARMUE_NSW_M2_37_M1_3
	aktiv
WARMUE_POL_M2_50_M1_8
	nicht_aktiv
WARMUE_RFS_M2_47_M1_9
	aktiv
WARMUE_SL_1_M1_14_M2_41
	aktiv
WARMUE_SL_2_M1_16_M1_18
	nicht_aktiv
WL_AL_MIN_PWM
	wert_01
WL_BL
	nicht_aktiv
WL_BL_MIN_PWM
	wert_01
WL_BLK_H_MIN_PWM
	wert_01
WL_BLK_V_MIN_PWM
	wert_01
WL_FL_MIN_PWM
	wert_01
WL_KZL_MIN_PWM
	wert_01
WL_NSL_MIN_PWM
	wert_01
WL_NSW_MIN_PWM
	wert_01
WL_POL_MIN_PWM
	wert_01
WL_SL_1_MIN_PWM
	wert_01
WL_SL_2_MIN_PWM
	wert_02
BI_XENON_BEI_LH_3R
	aktiv
CC_MELD_PARKLICHT_EIN
	wert_01
CC_MELDUNG_AL_L
	wert_02
CC_MELDUNG_AL_R
	wert_02
CC_MELDUNG_BFD_L
	wert_02
CC_MELDUNG_BFD_R
	wert_02
CC_MELDUNG_BL_L
	wert_01
CC_MELDUNG_BL_M_1
	wert_01
CC_MELDUNG_BL_R
	wert_01
CC_MELDUNG_FL_L
	wert_01
CC_MELDUNG_FL_R
	wert_01
CC_MELDUNG_FRA_H_L
	wert_01
CC_MELDUNG_FRA_H_R
	wert_01
CC_MELDUNG_FRA_V_L
	wert_01
CC_MELDUNG_FRA_V_R
	wert_01
CC_MELDUNG_IB_3R
	wert_01
CC_MELDUNG_NSL_L_3R
	wert_01
CC_MELDUNG_NSL_R_3R
	wert_01
CC_MELDUNG_NSW_L
	wert_01
CC_MELDUNG_NSW_R
	wert_01
CC_MELDUNG_POL_L
	wert_02
CC_MELDUNG_POL_R
	wert_02
CC_MELDUNG_RFS_L
	wert_01
CC_MELDUNG_RFS_R
	wert_01
CC_MELDUNG_SL_1_L
	wert_02
CC_MELDUNG_SL_1_R
	wert_02
CC_MELDUNG_SL_2_L
	wert_01
CC_MELDUNG_SL_2_R
	wert_01
CC_MELDUNG_SML_L
	wert_01
CC_MELDUNG_SML_R
	wert_01
CC_MELDUNG_TFL_L
	wert_01
CC_MELDUNG_TFL_R
	wert_01
DRL_TFL_MIT_SML_3R
	nicht_aktiv
DWA_UEBERFALL_ALARM_3R
	mit_tfl
FH_TUERAUF_STOP_MAUT_3R
	aktiv
HECKDECK_REVERS_ANZ_ZYKL
	wert_01
HECKDECK_REVERS_DOPPELB
	aktiv
LOAD_DUMP_DIMM_FRA_H
	aktiv
LOAD_DUMP_DIMM_FRA_V
	aktiv
LOAD_DUMP_DIMM_WERT_FRA
	wert_01
PARKL_FKT_MIT_BFD
	nicht_aktiv
PWM_BFD_3R
	wert_04
PWM_FL_FKT_DRL_3R
	wert_01
PWM_FRA_H
	wert_02
PWM_FRA_V
	wert_01
	wert_03
PWM_FRA_V_FKT_SIDEMARKER
	wert_01
PWM_KZL_3R
	wert_04
PWM_NSW_3R
	wert_01
SIDEMARKER_US_MIT_FRA_V
	nicht_aktiv
SL_FKT_MIT_BFD
	nicht_aktiv
VERBAU_ABBIEGEL_PL2_3R
	nicht_aktiv
VERHALTEN_DRL_TFL_3R
	tfl_s
WL_FRA_H
	nicht_aktiv
WL_FRA_V
	nicht_aktiv
CC_MELDUNG_KZL_3R
	wert_01
NSL_EIN_BEI_NSL_AHM_DEF
	aktiv
STROMSPAR_WARNBLINKEN
	aktiv
WL_BFD_MIN_PWM
	wert_01
ABBIEGELICHT_MIT_NSW
	nicht_aktiv
BFD_1_MIT_FRA_H
	wert_00
CC_MELDUNG_FRA_Z_L
	wert_01
CC_MELDUNG_FRA_Z_R
	wert_01
FH_HALL_DIAG_ENABLE
	nicht_aktiv
KALTUE_FL_M2_6_M1_04
	nicht_aktiv
KALTUE_FRA_Z_M1_11_M2_44
	nicht_aktiv
LED_LICHTFUNKTION
	nicht_aktiv
LRE_VERBAUT
	nicht_aktiv
NSL_AUS_BEI_FE_MODE_HECK
	nicht_aktiv
PWM_FRA_H_FKT_BFD
	wert_02
PWM_FRA_Z_AN_SML
	wert_03
WARMUE_FL_M2_6_M1_04
	nicht_aktiv
WARMUE_FRA_Z_M1_11_M2_44
	nicht_aktiv
LWR_SCHRITTE_STELLUNG_3
	wert_02
ASP_SPIEGEL_HEIZUNG_DELAY
	wert_01
IGR_ABBIEGELICHT
	aktiv
IGR_AL
	nicht_aktiv
IGR_BFD
	nicht_aktiv
IGR_BL
	nicht_aktiv
IGR_DAUER_BLK
	nicht_aktiv
IGR_DRL_H
	nicht_aktiv
IGR_FL
	nicht_aktiv
IGR_INNENLICHT
	nicht_aktiv
IGR_LH
	nicht_aktiv
IGR_NSL
	aktiv
IGR_NSW
	aktiv
IGR_RFS
	aktiv
IGR_SL
	nicht_aktiv
IGR_TIPP_BLK
	nicht_aktiv
IGR_WBL
	aktiv
KALTUE_SML_M2_8_M2_32
	nicht_aktiv
PARKL_SL_1_GEDREHT
	aktiv
WARMUE_SML_M2_8_M2_32
	nicht_aktiv
HALOGEN_AL_VERBAUT
	nicht_aktiv
FH_PARAMETER_0_3R
	e81
	e82
FH_PARAMETER_1_3R
	e81
	e82
FH_PARAMETER_10_3R
	e81
	e82
	e88
FH_PARAMETER_11_3R
	e81
	e82
	e88
FH_PARAMETER_12_3R
	e82
FH_PARAMETER_13_3R
	e81
	e82
	e88
FH_PARAMETER_14_3R
	e81
	e82
	e88
FH_PARAMETER_15_3R
	e82
FH_PARAMETER_2_3R
	e81
	e82
FH_PARAMETER_3_3R
	e81
	e82
	e88
FH_PARAMETER_4_3R
	e81
	e82
	e88
FH_PARAMETER_5_3R
	e81
	e82
FH_PARAMETER_6_3R
	e82
	e88
FH_PARAMETER_7_3R
	e82
FH_PARAMETER_8_3R
	e82
FH_PARAMETER_9_3R
	e81
	e82
	e88
IGR_TFL_S__DRL_S
	nicht_aktiv
SNU_NICHT_VERBAUT_3R
	keine_halldiagnose
SNU_TK_ABFRAGE_OHNE_PULSE
	nicht_aktiv
WL_KZL_3R
	soft_einschalten
WL_POL_3R
	nicht_aktiv
WL_SL_2_3R
	soft_einschalten
PM me your email addy.... I have the circuit diagram if you want to check the pinouts.
Thanks for the diagram. My harness is ok. Either coding problem or FRM3 has different pinout then FRM2 NSW...
More Ideas?
Sounds like you've put the wrong pin in the frm. At a guess. I'd wait to see what wiring diagram says. Could be frm pin position are diffrent in diffrent frm modules
It sounds like a wiring issue.
Just double check you haven't done it wrong?
I did mine by doing the wiring internally. I used power from the angel eyes and tapped that into the bi-xenon shutter (it needs very little power). Works perfect :)
Discussion Starter · #8 ·
I didn't change anything in the pins 6-11. Did not change anything in the rear lights (darkline led)
Only the middle stop goes on when I flash with high beams. Seems like front right high beam and middle stop are connected with each other somehow. Maybe something wrong in the plug @ frm3 or cables are damaged and current jumps from one to another...
Michael
· Vendor
What lights have you had before. On official retrofit from halogen to xenon pins 8-11 need to be changed aswell. I am sure not all are different.
Where did you get wiring diagrams from? Official WDS or just forums? Please pm me the guide you used as link from above doesnt work.
Frm3 will have the same pins as frm2. Just different models of frm have more "hardware" inside.
But if you have car with halogen and stick frm3 from xenon and code to halogen it will all work ad normal.
And coding if you added 522 and run blank file on frm it will be all good so my bet wiring is messed up.
Unless you frm3 is messed up but I would check wiring first.
· Vendor
Left headlight e126
Pin 8 to 50 on frm x14260
Pin 9 to 19 on frm x14260
Pin 10 to pin 15 on x14260
Pin 11 to pin 17 on x14260
Right headlight e127
Pin 8 to 51 on frm x14260
Pin 9 to 32 on frm x14260
Pin 10 to 28 on frm x14260
Pin 11 to 30 on frm x14260
Each pair has to be twisted pair so twist pin 8-9 and 10-11 on both headlight.
Also I think you car is LHD right? As x14260 is the upper one on RHD bmws;)
Discussion Starter · #11 ·
Arnie,
what are these pins on the headlight responsible for? What are these connected to?
Michael
· Vendor
MichalS said:
Arnie,
Michael
Hard to say what are they for without further looking into diagrams but they MUST be there.
They are connected to FRM as per post above, all pins are listed above.
Full retrofit guide on my server here: " onclick="window.open(this.href);return false;
Look on page 9 of PDF all is there and signal types.
Discussion Starter · #13 ·
Ok so pin40 on lower plug is for center brake light. It is right next to the pin 41 (of course) which I installed. I will remove all pins in that plug and install them in new plug. I think I might damage the plug and current hips between center brake light and bi xenon shutter.
I will keep you posted.
Arnie, all the pins for the leveler (8-11) on the headlamp are installed. Were already there. I will be installing level sensors in stage 2 of my retrofit.
Michael
Discussion Starter · #14 ·
I Think im running in circles here:
1. I removed pin 41 from the lower plug which goes to shutters in the xenons (pin5 on both headlamps.
2. With the pin removed and frm2 when I flash with high beam nothing happens
3. With the pin removed and frm3 when I flash with high beam third brake light lights up.
Is the pin assignment different between frm2 and frm3?
Discussion Starter · #20 ·
I dont have other frm3. Just the old frm2 NSW.
I'm thinking now whether i should change the VIN in FRM3 to match my car and change the production date. Some of the options in NCS dummy have date range as condition to work... Im trying to get SP Daten to update my WIN KFP to work. You guys know any link where i could get it?
Michael
1 - 20 of 52 Posts
