Car used - 57 Plate (late 2007 registration) 123D M Sport with 1000 miles on the clock (approximately). No other modifications other than lots of toys fitted as standard.
TUNING BOXES:
Spider:
1) Packaging is pretty basic.
2) Instructions are even more basic. Picture on the one side of A4 instructions provided was of a 2.0D engine, not the 123D as ordered - although the unit was correct.
3) The unit itself - looks very well made. It is very solid, perhaps aluminium and all the connectors are OEM units... (although I note a three spoked star on some of the plugs...
) The item is almost the same weight as a small house brick - approximately 50% the size as well.
4) Fitting the unit gives a good basic slug of power - it is noticeable. The unit seems to take some 100 miles or so to get itself bedded in - although this was not a scientific check, as I cannot establish the output. The increase in power though, is undeniable.
5) MPG appears to suffer on full load slightly - although overall, I noticed a bit of an improvement when I was not "TESTING" the unit.. if you get me
6) Item is sold with a warranty for the engine, but no mention of after sales support or user help.
P-Tronic:
1) Packaging - much higher quality than the Spider
2) Instructions - much more comprehensive, and clearer. Reference made to the help desk support in their company and warranty as well.
3) The unit itself is like a squashed version of the Spider unit - but in hard ABS plastic. The connectors themselves are OEM units again (one or two with the three pointed star..
) The item weighs less than a quarter of the Spider unit...! It feels like it is mostly fresh air... The item has a screw end box cover - unscrewing this reveals some terminals with adjustable resistors - setting this increases or decreases sensitivity - unlike the Spider unit which has no adjustability.
4) Fitting the unit is, as the spider, a matter of minutes - however, take your time - literally wait till the high pitched whine from the pump has cut out. You will be able to tell when this is by the blood stopping flowing from your ears, and dogs stop howling. Plumb the unit in- line into the common rail.
5) Like the Spider, it seems to take a couple of trips to really bed in. To begin with, I had the engine warning light come in straight away, before even driving it. Getting in touch with the help desk guys proved that shutting the car down totally, and restarting - over a few times - (in practice I also removed and refitted the item) seems to cure this.
6) Power does not seem as smooth or urgent as the Spider unit - and this appears to be different in different gears.
7) Power output is rated higher in the P-Tronic. I am going to get this rolling roaded to check out exactly what the claims translate to.
All in all - the Spider appears to be a simple fit and forget unit. The P-Tronic appears better for rapid service, support and adjustability - and allegedly another 20 bhp and 30NM of torque (or thereabouts) or so.
Hope this helps with anyone evaluating these. I have bought and fitted, and used both now.
P-tronic is interim stage before I go for a stage II full remap with some other gubbins to take me up to the 300bhp mark.
I am already breaking traction regularly on stock M Sport 205/225 tyres - although this is unsurprising, seeing as I now have more torque than a 2007 Porsche Carrerra 4S...
but dont have the four wheel drive or decent width tyres to get the power down...
TUNING BOXES:
Spider:
P-Tronic:
