1 - 6 of 6 Posts
Had these fitted with my winter wheels and tyres today to my May 2014 F20 M135 today.
CDWTPS Car Tire Pressure Sensor,433Mhz Tire Pressure Monitoring System(TPMS) sensor for BMW MINI Replacement#36106856209.36106881890(4-Pack) CDWTPS Car Tire Pressure Sensor,433Mhz Tire Pressure Monitoring System(TPMS) sensor for BMW MINI Replacement#36106856209.36106881890(4-Pack) : Amazon.co.uk: Automotive
I noted the idrive reset tyre sensors took about a 20 minute drive and stuck at 99% longer than i ever noted with the factory ones.
It still went green. So far no psi or temperature shown in about a 35 min drive. I guess that’s fine for winter tyres.
I’ll update here if is see any change or get any warnings/errors.
I got 4 brand new oem ones fron German Ebay for £99 once fitted there worked straight away no coding required.
Discussion Starter · #5 ·
Reading the info on the listing coding may be required before they will work properly.
I did a second reset today. Went to 100% in about 8 mins. Now shows temp and pressure.
All good, no coding required.
  • Like
Reactions: marco_polo
Discussion Starter · #6 ·
No further differences from the ones that came on the car from new so far.
1 - 6 of 6 Posts
