I have this ticking noise while the engine is running, cant really hear it inside the car but is audible when your outside the car, any ideas what this could be? I have an E87 116i 2008
I think I might have the same problem today for the first time my engine oil light came on even though through the on-board check it said it was fine, how much did to replace?GeoffCollins said:I had a ticking from my old E87 BMW 116i 2009, it started off as a small ticking but then became louder as the weeks went past,
Turns out it was the timing chain tensioner, cheap and easy to replace, might be worth seeing if that is all goodhope the 1er is okay
I should say that i found out when the car started leaking oil out of it and had to pay to get it towed![]()
sell it ??? I just bought it im going to get it checked out soon, this better not be the case.Stuw101 said:I would sell it quick! Likely to be the cam chains. All the vehicles between 2007 and 2011 have a dodgy sprocket on them. I fell into the same trap not knowing. Just cost me ÂŁ1287. Bmw gave me a gesture of good will even though this a known manufacturing defect and they have been on watch dog for it they would only pay 100 percent parts but only 30 percent labour. Hence ÂŁ1287! Still has the engine management light on on it
Nothing but trouble
It was only like ÂŁ120 or something to replace, got it done at a non-bmw garage though, because it was quite obvious what was wrong.Giggs said:I think I might have the same problem today for the first time my engine oil light came on even though through the on-board check it said it was fine, how much did to replace?GeoffCollins said:I had a ticking from my old E87 BMW 116i 2009, it started off as a small ticking but then became louder as the weeks went past,
Also im not sure exactly where the sound is coming from but its always there so from cold start.
