Have a MY06 E87 130i Sport in need to a suspension refresh due to age and distance traveled.
Looking to fit the Birds B1 Dynamic Package < B1 Dynamics Package Upgrade - BMW E87 130i and E82 135i | Birds > which includes their version of the Bilstein dampners, Eibach coil springs and ARB (swaybars) to suit. The Birds B-Series suspension kits include bump stops.
I believe that in addition I will need new strut tops for the front and rear, and new ARB links. Any thing else needed for installation of these?
I was looking to also fit the M3 control arms to the front, but recieved the following from Birds Auto:
"We prefer to leave the arms alone. If you wanted to make a race car out of it you might benefit slightly from the negative camber but we feel it's not really necessary for a fast road car. Kevin actually took them off his 130i in the end due to tramlining issues (although I'm not sure that was conclusively the arms' fault). As a principle we try not to fettle with too much on any car as you can end up sacrificing the integrity of the car, we just try to address the key areas. The only upgrades he had on his 130i when we developed the kit were the ARBs and Quaife LSD.
With the control arms am I correct that it is the Lower Control Arm that alters the vehicles camber?
Why is the Upper Control Arm also generally included in the kits? Or are both usually changed together due to the different suspension bushes used in the M3 Control Arms?
What about the rear control arms? Do these have an effect or is it again just for the better suspension bushes?
What other bushes should be replaced while there? Rear Differential Mount? Rear Subframe Void Fillers?
Vehicle is for on road, not track. Would like it to drive nicely on backroads too.
Has anyone with the Birds B1 kit tried the M3 arms too?
