This arrived today!
I'm thinking of trying that stuff once my Polar Blast runs out. I hear it has the best cleaning power. What mix ratio do you use?![]()
Bilt Hamber auto foam. Got to be quick with this stuff!
Roughly 1:4I'm thinking of trying that stuff once my Polar Blast runs out. I hear it has the best cleaning power. What mix ratio do you use?
Without question :When it comes to
Absolutely correct.
When it comes to using snowfoam in most situations, this guy has it sussed I think. I now use mine in the way he suggests
I suspect Twenny may have a point, but it makes me happySo basically snow foaming your car does jack sh!t, it’s just something cool to do![]()
Hah! He does like to pad things out, doesn't he? But he does test things very, very thoroughly, more so than any other detailing channel I have seen. He did suggest that a possible benefit (after you'd jet washed the car to get loose dirt off) - that you have a more lubed surface to aid your 2-bucket wash, and which is now how I use it. (That is, jet wash, then leave the suds on whilst I bucket wash). I would agree with an earlier post, however, that if you have an intact ceramic coat then snow foaming might have some impact.Without question :
THE MOST BORING VIDEO I HAVE EVER WATCHED
I won’t be copying this guy anytime soon![]()
Oh I snow foam every time so I’m not arguingI suspect Twenny may have a point, but it makes me happy![]()
I shall be investing in a purifier tank next month like this -
This way I can let any foam run off instead of dry and water spot the **** out of my car
@moulin - if the aim is to lift “some” dirt, surely you would want to rinse that off before doing a 2 bucket wash and rubbing that dirt into the paintwork
1. Rinse the car thoroughly with jet wash
2. Citrus snow foam fairly watery so it runs off
3. Bilt Hamber spray wheels at same time
4. Rinse off
5. 2 bucket wash
6. Rinse off
7. Dry with 2 extra large microfibre cloths
8. Open doors and wipe seals and door frames down
9. Apply QD to MF towel, wipe on and buff off
10. Apply window cleaner
11. Apply wheel sealant
12. Have a beer![]()
I mix my BH foam with their Surfex HD prewash too and in the winter it'll just drag all the dirt and salt off the car so you don't have to contact wash it really. Great for just blasting the car off if you don't have time to give it a full proper washI want to try the Bilt Hamber auto foam. General consensus is its fantastic. Dosent foam up as well but pulls more dirt off the paintwork prior to hand washing.
Moulin?Tweeny, it's not left there to lift some dirt but to add additional lube in your 2-bucket wash, as I said. Of course, you jet wash first to remove any loose dirt.
If using a DI vessel in line with a jet washer, rather than a hose, you may find that you'll need a 2 in-line set up, as a single may not have the capacity to cycle water at the rate of your jet washer.
I bought mine from Daqua, as they seemed to be slightly better value
Resin prices have shot up since covid (think India is a main supplier) - twice the price now, as compared to even a couple of years ago.
