I’ve never heard of “carriers“ in a braking system. Are you sure youve not mis-heard the word “callipers”?
The calliper holds the pads, and the hydraulics that push and retract the pistons that push the pads against the discs.
Carriers?
I’ve never heard of “carriers“ in a braking system. Are you sure youve not mis-heard the word “callipers”?its the part of the brake that squeezes the pads against the discs. BMW believe that they need changing as im assuming they stick when reversing.
anyway, i had discs and 4 sets of pads for the noise. nothing.
carriers changed and all good so far.
Which is different to the answer you gave that triggered my questioning……
No im sure.
The carrier holds the caliper in place. Its like a bracket usually steel and this holds the calipers in the correct place for when the caliper and pad are depressed against the disc.
Carriers?
its the part of the brake that squeezes the pads against the discs. ………….
fair point. i typed calipers instead of carriers without thinking earlier however it doesn't change i heard correct, read the works sheet correctly, and understand what the difference is.Which is different to the answer you gave that triggered my questioning……
