Sure you wanna give it a go?
I think this is one of the few jobs I'd pay a garage to do.
I'm the same. Have rebuild motorbikes from nuts and bolts. Not much scares me.Lippo said:Yeah, why not.
I've done various things in the past to the car - installed Bluetooth, fitted cruise control, stuff like that. I'm relatively mechanically minded, just like to have advice and don't like spending money at the garage when I'm competent enough to do the job myself.
It's such a shame as well mate that you're having to drill them out. That's a 50/50 job as well so much stress..willgladwell said:They are now having to drill these out at great expense to me!
I would strongly advise that you let a garage tackle the plugs
The garage told me its 60/40 whether they will be able to drill them out in situIt's such a shame as well mate that you're having to drill them out. That's a 50/50 job as well so much stress..
Guess you just gotta be very gently and patient with this job.. Lube it up a couple times over night if anything lol
All good advice. Also ensure that you have a good quality, snug-fitting long socket, and suitable extension bars & joints that allow you to apply torque in direct line with the glowplug thread. If you do all of this, most of the time a diesel glowplug will come out easily enough. And then it's £10 or so for a replacement, and you can feel smug. But everyone has a story about seized glowplugs, and costly engineering works to get them pulled or drilled. Worst case is snapping them off or stripping the thread.Anish1993 said:Numerous soaks with a lubricant over night perhaps..
Get the engine very very hot before attempting
And remove them very gently.
Did you do the glow plugs? how did you get on ?Lippo said:Thanks for the advice. If there's any problem witha glow plug, I'll leave it in place.
As for why, I did read a couple of glow plug errors some time back so think that at least 2 will need changing. Starting is also slightly lumpy, which I'm putting down to damaged/old glow plugs.
I've bought 4 Bosch plugs for £40 so it's not going to break the bank.
I've also read that they can assist the stop/start function, which has fallen by the wayside over the last few months as the battery gets older.
