Rear Washer not working (SOLVED) with pictures
24K views 5 replies 5 participants last post by  riccie_120i
:thumbs:
Good work, and clear pics.
Just one point of advice, given the blockage was inside the wiper motor, you can probably expect that to sieze up at some point. Check that when you're using the washer, its not flooding inside the motor; it probably is, as the tube through the middle is probably corroded. You can strip the motor and clean it up, but in my experience it only lasts another few months, so if you're keeping the car, its worth just replacing it (easy enough given how much you're demonstrated you can do :)).
