1 - 5 of 5 Posts
I happen to have a set of winter tyres lying around. But all 4 tyres are 225/45/18. I know the front tyres should go on fine, how about the rears though?
Would a 225/45/18 fit onto our oem m135i rear rim? Or would a tyre place turn me away?
I have a set of 225/40 R18 all round on the OEM 436Ms.
A profile of 45 will probably skew the speedo a little bit but otherwise *should* be okay.
225 is certainly okay to fit onto the 7.5J rear.
The rear is 8" wide.
I have a set of brand new winters 225/40/18's to go on my full set 436's. Will fit no problem.
Whoops, you're right. Getting my fronts and rears mixed up.
Discussion Starter · #5 ·
Ah cheers lads. Once the standard Mich PSS wear out. Il put the winters on the oem rims, and buy a decent set of aftermarket wheels for a fresh set of PSS tyres.
1 - 5 of 5 Posts
