My car is poor with PS4 F & PS5 R. Dodgy handling over 50mph, even though the tread pattern is identical. I won’t be mixing again.
Tread pattern on PS4 is different to PS5, they're really not the same tyre. I'm not interested in the PS5 as it's no better than PS4 in terms of dynamic steering feelMy car is poor with PS4 F & PS5 R. Dodgy handling over 50mph, even though the tread pattern is identical. I won’t be mixing again.
Thanks for the reply. I would definitely agree that mixing tyres front and rear is not advisable if you care about good handing and performance nearer the limits. However the PS4S is the same tread pattern as the PS4, it's basically a PS4 with stiffer side walls and different compound on the outer shoulder to help with track use and harder driving. That's why I wondered if it might work? I suspect someone has tried PS4S front PS4 rear due to lack of availability of PS4S for the rear wheels.If you are only going to consider the exact configuration you propose it is likely to be a very small set of people.
I think the wider point made by 120 is that they were unimpressed with their mixed set.
This is regularly raised.
I had F1 ASSY 4 on the rears and MPSS on the front for a while. It felt very odd from the front "floaty" and the TC definitely didn't like it.
I also briefly had ASSY 5 on front with ASSY 4 rear. That was odd too.
Universally folk raising it don't like it. (But that's hardly surprising, nobody mixing is likely to post that it's ok to them.)
I do end up mixing at each change, for cost. I personally wouldn't fit anything I couldn't match to later.
That was exactly the point, mixing tyres of any sort on these cars causes problems. I don’t like the PS5 so far, so would not recommend them.If you are only going to consider the exact configuration you propose it is likely to be a very small set of people.
They very well be the same tread pattern but that’s about the extent of the similarities. The 4s has different tread compound make up to the PS4. There was a lot of guys having issues with TC intervening even on light throttle on RS3’s with 4s in the 255/235 staggered fitment. So much so Blackcircles (owned by Michelin) started to decline sales if there were going on an RS3. Slightly different situation going on an AWD car but it also highlights how slight differences can cause unforeseen issues. Personally I would never mix tyre models. The compound alone could cause grip or traction imbalance not to mention the sidewall differences. Running a tyre with a stiffer side wall on one axle and softer on the other could promote a more vague floaty handling characteristic, something the F20/21 chassis doesn’t need help with.Thanks for the reply. I would definitely agree that mixing tyres front and rear is not advisable if you care about good handing and performance nearer the limits. However the PS4S is the same tread pattern as the PS4, it's basically a PS4 with stiffer side walls and different compound on the outer shoulder to help with track use and harder driving. That's why I wondered if it might work? I suspect someone has tried PS4S front PS4 rear due to lack of availability of PS4S for the rear wheels.
I’m so glad I sent my ps5 back and ordered some ps4 for my rears (thanks OneTwenty) . I’m running a 245/255 ps4 set up and find they grip really well in the cold and wet.That was exactly the point, mixing tyres of any sort on these cars causes problems. I don’t like the PS5 so far, so would not recommend them.
So you're happy with PS4 all round? I have them on my M240i (Std 18" wheels, Bilstein B8 shocks, Eibach lowering springs and 15mm spacers) and like the all weather grip they have but find the fronts a little numb in dry weather compared to the old Pilot SuperSports. Better all round tyre though, seems you can't have it all in one tyre. Apparently the Conti SportContact 7 tyre is excellent and feels dynamic (according to Jon @ TyreReviews) but can't get rear 18" tyre size for mine.I’m so glad I sent my ps5 back and ordered some ps4 for my rears (thanks OneTwenty) . I’m running a 245/255 ps4 set up and find they grip really well in the cold and wet.
Yeah, I’m really impressed with them. There the only tyre I’ve had so can’t comment on others 👍So you're happy with PS4 all round? I have them on my M240i (Std 18" wheels, Bilstein B8 shocks, Eibach lowering springs and 15mm spacers) and like the all weather grip they have but find the fronts a little numb in dry weather compared to the old Pilot SuperSports. Better all round tyre though, seems you can't have it all in one tyre. Apparently the Conti SportContact 7 tyre is excellent and feels dynamic (according to Jon @ TyreReviews) but can't get rear 18" tyre size for mine.
Do you think going 10mm narrower (235 instead of 245) on my rear OEM 18 inch wheels is OK? Car runs 420bhp and 540Nm torque so rear traction can be an issue. I had considered going 10mm wider on the rear using 255 tyres but have been advised against it on the forum.Both the PS4S and SC7 are available in 235/40 R18 which fit the front and rear OEM rims.
Could be combined with 265/30 R19 rears in line with a dual rim size setup of the latest M cars.
Thanks Bimmert. Rear traction will be much more of an issue for me than your X-drive setup, your front wheels can pull to avoid the rears being over stressed for traction. Getting a set of 19 inch wheels is an option but I think the ride would be too harsh on my passive suspension setup now I have the B8 shocks and lowering springs fitted. I know they're OK with adaptive suspension but I prefer the passive setup and OEM black alloys. Hopefully Michelin UK will reply to me tomorrow and I'll be able to post their response for everyone to see. Fundamentally the PS4 (non S) 225/40 & 245/35 18" staggered setup I have is good for all seasons but I miss the more dynamic feel of the original Pilot SuperSports on the front in dry weather.With stock power I have no issues putting the power down with a square 235/40 CC2 setup, gave it full beans after rub in last week and the traction light stayed off and the car tracked nice and straight. If the CC2 can handle 340hp / 500Nm the UUHP tyres should be able to handle your specs. Please be aware I have xDrive so results might vary with RWD.
But why not go for a dedicated 19 inch summer set with multiple UUHP choices for 245/255 or 235/265 rubber?
In 18 inch the Asy 6 performs very well btw, in this review its close in the dry to the SC7 but beats it in the wet:
2022 AutoBild 19 Inch Summer UHP Tyre Test - Tyre Reviews and Tests
For AutoBild's third summer tyre test for 2022, the German publication tested ten sets of 245/40 R19 tyres using a BMW 5 Series.As this is the first test with both the new Goodyear Eagle F1 ...www.tyrereviews.com
I wish I’d stuck with the PS4. 😬I’m so glad I sent my ps5 back and ordered some ps4 for my rears (thanks OneTwenty) . I’m running a 245/255 ps4 set up and find they grip really well in the cold and wet.
I loved PS4 all round on my 240, but the PS5 are rubbish in comparison. The rear no longer has the wet weather grip of the PS4, in fact it’s not much better now then the MPSS. I wouldn’t recommend them at all. If I had the cash I would go back to ps4 and ditch the new ps5 but I have to live with them now. 😢So you're happy with PS4 all round? I have them on my M240i (Std 18" wheels, Bilstein B8 shocks, Eibach lowering springs and 15mm spacers) and like the all weather grip they have but find the fronts a little numb in dry weather compared to the old Pilot SuperSports. Better all round tyre though, seems you can't have it all in one tyre. Apparently the Conti SportContact 7 tyre is excellent and feels dynamic (according to Jon @ TyreReviews) but can't get rear 18" tyre size for mine.
One of the reasons I went for the PS5 was because of that review, but I also thought exactly the same at the time - how can the tyre last so much longer without affecting grip? Well it does affect grip in my experience.Strange isn't it, Jon on TyreReviews (reputable tyre review YouTube channel) rated the PS5 highly, an evolution of PS4 he reckoned. When Michelin talk about much longer life from the new PS5 tyre that surely can't translate to better grip as the rubber compound has to be harder? I'm getting good life out of my PS4 tyres, 9k miles and still over 5mm all round, they should do over 15k miles which is fine by me. There's a PS5S on the way at some point I think. Perhaps tyre reviews can be misleading unless they were done on the car you actually drive. He used a Golf GTI with 225/45 R17, nowhere near the torque levels of a 140/240 and of course fwd. Having checked the review again the new Goodyear Asymmetric 6 beat the PS5, more dynamic handling and as good as PS5 in most other areas. Maybe the Asymmetric 6 is a tyre to try? I nearly bought their F1 SuperSports when I got the PS4 tyres but was no availability of rear tyre size and couldn't wait months for them to arrive.
