Thanks- I did a test with both INPA and ISTA and they show basically the same error codes for PDC
CAS --- 0x00A0B3 CAS: Starter motor, terminal 50 248472 No ---
CAS --- 0x00A126 CAS: Implausible signal from engine management 247088 No ---
D71N47A0 --- 0x004000 DDE: Fuel-temperature sensor, signal 248720 Yes ---
D71N47A0 --- 0x00493F DDE: Presupply-pressure sensor, signal 248712 No ---
D71N47A0 --- 0x004B1C DDE: Fuel-filter heating, activation 248560 No ---
DSC_87 --- 0x005DF4 DSC: Battery voltage too low; open circuit 248184 No ---
DWA_E65 --- 0x00D947 DWA: K-CAN communication fault 0 Yes ---
FRM_70 --- 0x00A8C1 FRM: Reversing light, left, faulty 248264 No ---
FRM_70 --- 0x00E598 Message (driving light) missing, receiver FRM, transmitter RLS 248696 No ---
IHKA87 --- 0x00E723 Message error (status condensation window glass front, 0x2D1), receiver integrated automatic heating / air conditioning system, transmitter roof function centre 248696 No ---
JBBF70 --- 0x00A6CD JBE: Rear-window wiper blocked 248616 No ---
KOMB87 --- 0x00A559 Instrument cluster: Power supply has been switched off (closed-circuit current cutoff relay) 247096 No ---
MRS5 --- 0x0093D2 MRS: Telltale lamp for front passenger airbag deactivation 248696 No ---
PDC_87 --- 0x009E33 PDC: Lines, rear left, ultrasonic sensor 236608 No ---
PDC_87 --- 0x009E36 PDC: Lines, rear middle right, ultrasonic sensor 0 Yes ---
RAD2 --- 0x00C56D Connection, headunit to microphone: Open circuit --- Unknown
The car has a sensor missing in the rear bumper- I don't know whether it's fallen out completely or it's been pushed in and hiding behind the bumper. Is it true that if one sensor is not working then it'll throw up the error code on the dash and the module won't work at all? In which case if I buy and fit the new sensor then the parking control should function ok?
