1 - 10 of 10 Posts
I have just had my ABS pump repaired for a second time and still have the amber parking and traction control lights on. The fault codes are 5DA3 and 5D93 which are the front left and right wheel speed sensor fault codes. I have been googling the repair which seems very straight forward. What I can not find is the correct part number for an E81 BMW 130i on Bmminiparts as I can not find the correct OEM diagram! I (think) the part number is 34526760424 but I would rather confirm on a parts finder as I think there is a different part for 6 and 4 cylinder cars. Does anyone have a link to the correct parts diagram or know which category the part would be listed under? Thanks
E82 135i/1m ,2018 240i
These should be available cheap from the factors now also
And I think the only differences are before and after 2007 as the pick up rings changed
Pre 2007 used normal trigger rings and after used the wheel bearing seals
Sods law I have a 57 plate car...I guess it could be either depending on manufacture date. I will take one of the front wheels off on the weekend and see if I can see a part number on the cabling. Prices on the part really seem to vary, £17 to £30 as a patent part, £30 OEM from Bmminiparts and £80 or so from BMW!!
It's probably easier to see if you have rear reluctor rings on the drive Shafts if you have then it's Pre 2007
Discussion Starter · #5 ·
Its an E81 3 door so in theory it has to be post 2007. I know people have found that 2007 cars sometimes have a bit of a mix and match of parts used?
Have you looked on real oem? If you put in your vin it'll give you a build date.
I don't think an E81 with have any pre facelift components. It was a whole new release. A 2007 E87 may have, but an E81 won't.
Discussion Starter · #9 ·
RealOEM lets you search by part no. and the resulting page has a link to the diagram its on. Looks like the part number you quoted has been superceded by something newer.
1 - 10 of 10 Posts
