1 - 3 of 3 Posts
Long time lurker, first time poster.
What a wealth of information you guys have put up. Any problems I have had, you guys seem to have already come across them and found the answers, so I've never had anything to add, you lot are already too good!
I've had a good search and can't find an answer so here's hoping.
I have traction control and the parking brake light up. Pretty sure it's the ABS pump thing throwing a wobbly and it will need replacing.
Just to make sure I bought a wifi OBD2 scanner and got these codes C0C12, C0DFF AND C0E09. I was hoping someone could tell me what they are as I can't seem to find any info on the codes.
Any help/guidance would be much appreciated.
Have you checked your reluctor rings? Sounds like classic signs of failure to me. Have a search about it.
Don't let anyone tell you that you need new half shafts, you don't, the rings can be repaired easily enough.
Pretty common problem and it seems to be this time of year they fail.
· Super Moderator
Does sounds bit like DSC hydro unit failure.
I've got a funny feeling you need to take a look at your swirl flaps too.
1 - 3 of 3 Posts
