1 - 20 of 27 Posts
· Premium Member
Hi guys,
Was heading down the M5 this morning so activated the cruise control (retrofitted by BMW).
As I called to speed up from 65 to 75mph the car hesitated before the power came in.
Then I had a warning message and the car went into 'limp mode'.
I'm taking it in to get the fault read tomorrow but anyone got any ideas?
Cheers for any help! :)
Andy
vanos solenoids or something being my guess.
· Premium Member
Discussion Starter · #4 ·
Will update tomorrow when codes are read.
Could it be anything to do with the retrofit of the cruise control?
Not experienced anything like this when driving manually...
I suspect it's just coincidence.
Whats the mileage on your car?
AndyBish135i said:
Done 29,000 on a 10 plate so not much
Have a look at your vac lines as low boost also throws the car into limp mode!
Few guys on N54tech & e90post replaced their lines around 25-35k due to splits.
Check both lines that run from the bottom of the boost canisters and from both recirc vales to the splitter then back to the engine all of those were split/cracked on my car and they had only been replaced 2 years ago (covered less than 20k in that time).
Is there no one on here around you that could check the code and reset?
Here is the thread I posted when I changed mine " onclick="window.open(this.href);return false;
· Premium Member
Discussion Starter · #11 ·
Now I am confused...!
Started her up this morning and drove to work with no faults whatsoever? No Limp Mode and Full Power available?
Taking her in to get the codes read at lunchtime anyway and will post what they are...
· Premium Member
Discussion Starter · #14 ·
Ok, had the codes read...
2DED power management quiescent, current fault intermittent
30FF turbo pressure measured too low, intermittent
Anyone got any ideas?
Cheers,
Andy
You mapped at all? Charge pipe could have cracked or come off.
To be honest I'd just start with the vacuum lines! Check the ones I mentioned previous, as as said all of mine were cracked/split.
If they are replace with silicone
Have u had any waste gate rattle as 30ff is sometimes the code u get for failling turbos check everything else 1st tho
1 - 20 of 27 Posts
