Hey all
Ive had a long running niggle with my 125i - in relation to a slight lack of performance and not running as smoothly. Whereas ive not had much to go on, i now recently had some symptoms to go by what’s causing it but now have various ones that may or may not be related so am hoping to get some insight. - Sorry this is a bit long winded.
(Just for the record i have newish plugs/coils, VCG, air filter and with annual oil changes etc)
I currently have the following codes
2A31
Ox2A31 Valvetronic, eccentric shaft sensor: guide
2A33
Ox2A33 Valvetronic, eccentric shaft sensor: guide
2A35
Ox2A35 Valvetronic, eccentric shaft
sensor: guide
29E0
Ox29E0 mixture control
29E1
Ox29E1 mixture control 2
2A37
Ox2A37 Valvetronic, eccentric shaft sensor: plausibility
The car seems a bit lethargic at lower speeds mainly, the fuel consumption is higher and im also occasionally getting a vapour-ey burnt oil/rubber type smell along with a high pitch squeak from the oil filler cap area when applying throttle (again all may or may not be related. However my idle is smooth (has been lumpy before) and oil doesn’t appear to be dropping/burning. The revs sound a bit knocky at times but not all the time.
So i took my car into my indy bmw tech to see what on earth is going on. Unfortunately after doing smoke tests, diagnostics checking DME tolerances etc- apart from the obvious ESS fault, he could not find what was causing the mixture control fault and whether everything was related. Also no signs of any vacuum leaks. He advised it is running just within tolerances before ISTA flags up whats at fault with air/fuel ratio - but acknowledged its not quite driving 100%. Of course the replacing the ESS will help but has advised not to do this until we’re completely certain whats causing the mixture control fault to rear its head.
A bit frustrating but at least he has not advised to throw parts at it. As all this testing is costing money i will stop pulling it apart - at the same time I would like to try try at least narrow down if im looking at something really obvious that everyones overlooked or its just unfortunate that a few things have started failing at the same time - unsurprisingly over winter. The possibility of it being an 02 sensor or injector has been considered.
2A31
2A33
2A35
sensor: guide
29E0
29E1
2A37
