Do i seriously need branded BMW 5w/30 oil at £16 a litre?
BMW certified oil is:
ACEA C3 - Stable, stay-in-grade oil intended for use as catalyst compatible oil in vehicles with DPF and TWC in high performance car and light van diesel and gasoline engines, with a minimum HTHS viscosity of 3.5mPa.s. These oils will increase the DPF and TWC life.
Warning: these oils are unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
ACEA A3 - Stable, stay-in-grade oil intended for use in high performance gasoline and direct-injection diesel engines, but also suitable for applications described under A3/B3.
ACEA B4 - same as above
The cheaper Castrol oil i found at 5/30 doesn't have ACEA A3 or ACEA B4.
I thought BMW didn't make fuel and it was merely re branded Castrol oil so they can put a mark up on price?
Can someone advise?
Thanks.
Can someone advise?
Thanks.
