1 - 19 of 19 Posts
Hi Guys,
I went in to BMW and they want £280 for front pads....
Has anyone replaced these themselves and got any links for me on where to order?
Thanks, seen some EBC Red stuff pads but not to sure if they definitely fit.
Regards
E82 135i/1m ,2018 240i
I have ebc yellow stuff and the fitted no problem, a very simple job to change them
Sent from my SM-P900 using Tapatalk
im just struggling to find the correct ones online as there are many diiferent types and i have the bmw performance calipers
Discussion Starter · #7 ·
Thanks Rob, do i need to then get the sensors?
you'd think so shins!
· Super Moderator
Yes, always one new genuine sensor from BMW.
Or two if you're doing front and rear brakes together.
George, I assume this also includes "a bit" of labour at £280 ?
Still pricey but maybe they are charging 1 hour at £120 ?
· Super Moderator
Shins said:
Do people generally stick with standard pads?
Or anyone tried Ferodo, Pagid etc
I've had no performance issues with the standard pads.
I wouldn't mind a lower dust pad though, as long as they performed as well.
Yes, I am surprised how well the std road pad has survived track use. I think the calipers/discs are generous enough to help dissipate enough heat and prevents too early an exit.
alackofspeed said:
EBC pads are the worst I've ever experienced, be it green, red or yellow compound! Plain scary!
I've only ever heard bad reviews from people that track regularly. But good reviews from road users.
I agree the std pads aren't bad at all. Even on blyton park which is short and tight. Good 10-12 laps before any fade.
Discussion Starter · #17 ·
Thanks guys for the replys, blind ill have them off you fotr definite mate, need to get them on next weekend, have you got a sensor aswell?
does this need to be bought from BMW?
1 - 19 of 19 Posts
