Fitting the Alpine system upgrade - long but may help you out.
Kit comes with these....
I decided to start with the part that I thought would be most difficult, routing and connecting the harness. I don't think the instructions mention removing the boot liners, but if you want to make this an invisible install, this is worth the effort. My car is the Coupe, but i assume most others are similar.
Remove the left and right boot liners, this initially required removal of the rear cover 2 screws (phillips), and twp push in clips. Both liners were also held in with a further 3 push in clips, plus the eyelet covers for the tie downs fitted to my car. This needed the correctly sizes torx socket. Remove the boot floor and the liners.
Then remove the rear seat base, this was simply a matter on tugging up on the front most section until about 4 clips released and it came out very easily.
Then lift of the covers between the carpet and the doors. Start at the front lifting vetical - working your way backwards. The last clips is does not come out vertically, but about 45 degress inwards so be carefull not to damage the trim. Most of my clips actually stayed in the chassis to be pulled out and refitted to the trim later.
You then need to find the connection points for the harness. On the passengers side (LHS) the connectors were much further forwards in the car than I expected, nearly under the cover to the left of the footwell. BMW have left plenty of extra cable, but getting it out proved to be somewhat of a challenge. You need to find a tool to cut the felt tape, whilst trying to avoid the wire insulation. I started with a craft knife but resorted to a small pair of scissors when I saw some of the damage I was doing to the wires - you have been warned! Once you get these cables out you need to cut off the connector that joins the three wires together.
You can now route the harness to this area around the rear seat side bolsters and unders the rear side panels (make sure you go the correct side of the seat belts!). It's worth making the connections before pushing the harness down under the carpets as it gives you more movement when making them.
The kit comes with crimp connectors - you need good quality crimp tools to use these succesfully. I've got these but chose to use connector blocks with screws as I've lots of confidence it these (I know they're not the best looking connection method), but they are reliable and you can't see them under the carpet.
Now the hard bit. On the LHS you need to identify the cables. The one going forwards is the one for the front speakers, easy. Unfortunatley there are two sets of wires going rearwards and although you can see they split out from the main harness further back (one to headunit, other to subwoofer), it is hard to tell which is which because they travel in the main loom for about 25cm. I took a risk here and decided to connect two wires to the front speakers and then turn on the radio. This way if I connected the subwoffer the the speakers I'd get no sound. If I connected the radio, I get sound. First of all I connected the sub, and then turned on - no sound. I then turned everything off and tried again with the other set of wires - bingo. Found the radio feed etc. No damage to my system but this is your call!
Anyway, now you've identified the wires you can make the connections as per the instructions. This is pretty simple.
Tuck everything away - I waited until testing before fitting the trim strip.
Driver side is easier because the connections were just in front of the rectangular section across the car that the seat bolts too. Again, getting the wires out was fun! but once out it was easy to see where the wires went and I didn't need to do the 'radio switch on' to identify them. One set went forwards to the speakers, one set went across the car to the radio, other set went under the seat to the sub. Again, after cutting off the connectors and stripping back, make your connections and you're sorted.
I then decided to re-fit the boot liners, don't make the mistake I did and fit them before making the earth connection. You should (I didn't but you should) connect the earth cable to an earth point under here. I made another point for mine as shown in the picture.
I then fitted the door speakers - not something I was looking forwards too. Remove the door handle trim - I started at the bottom and managed to get the ball rolling without prizing with any tools - give it a hard tug and it came off with no damage. Remove the cover for the screw in the rear of the door panel above the door pocket - I used a small screwdriver and it came out with no damage. It did ping off into the gravel so watch out for this. Remove the torx screws, two in the door handle, one above the door pocket (T20 I seem to remember) then the really miserable bit - wedging the panel off. I pushed a plastic spatula under the front of the panel (between the metal and panel). This wasn't enought so I pushed a metal scraper between the spatula and the panel - this worked a charm and the first few clips came out. You can then get your hands behind the panels and pull it off. The top clips are a different design and must be pulled out horizontally or you'll damage them. The panels are really tight but it wasn't as bad as I expected and they came off very well. Only one clip stayed in the door itself and I pulled this out with pliers. I left the cables connected to the window switches and the striker and supported the panel on a box with some cushons whilst I changes the speaker and fitted the tweeter and cover, and the x over network. This was all pretty simple. Refit the door panel (make sure you put the lock-pin back into hole if its dropped out) and then clip the panel all around. Fit the screws, fit the cover above the door pocket and then the handle cover. Be careful with the handle cover - I damaged the clips on both of mine by not aligning them properly and getting them stuck. They seem OK, but I know they're not perfect which does my head in.
Repeat for the other side exactly the same.
Once this is done it's all really easy. Ensure the switch is set correctly on the amp before you mount the amp in the boot using the sticky pads in to the space under the floor. Connect the positive cable to the connection on the plastic tray near the battery.
Then plug the amp in as required.
The amp actually takes a second or two to turn on (rear speakers come alive first). I assume the amp uses the speaker signal to tell it to turn on. This is a bit of a pain when using stop - start as the fronts cut out for a moment everytime the engine starts. Sounds much better though.
Re-fit all the trim. Rear seat clips into position - so do the side trims. You're all set. OH - don't forget the Alpine emblems, I'll let you work these out.......!
Feel free to ask any questions.
