Hi guys,
We went out in the 120d SE this evening and noticed that the windows were misting up, and then realised that there was no noise from the heater fan.
The climate control panel is lit up and functioning - and you can hear the ventilation flaps (or whatever they're called) moving behind the dash when you change a setting. But the fan/blower doesn't seem to be operating (you can't hear/feel it even with the fan setting on full).
My first instinct was to check a fuse, and found the panel behind the glovebox. But I'm not sure which one I should be checking!
There are 3 possibles from the list attached to the back of the panel:
No. 60, Air conditioning/heater - 10 amp
No. 69, Electric fan - 60 amp
No. 67, Fan - 30 amp
Since they seem particularly fiddly to access, does anyone know which one its likely to be?
Or has anyone else had this problem before? If its not a fuse, I guess its going to be £££ to sort out. Shame the car less than 2 months outside the warranty period!
Cheers,
Steve.
Cheers,
Steve.
