For my 2022 Covid retirement project I bought a moribund 2013 BMW 118i sight unseen. The owner said that the car went into limp mode and after that wouldn't start. But he wasn't going to go into details. After a bit of reading up I got the impression that the problem could well be electronic, and might give me the opportunity to don my dust coat, and get some use out of my stethoscope, newly acquired endoscope and diagnostic tool. A proper white gloves job.
It was therefore with some disappointment that I observed coolant running out of the exhaust pipe when the vehicle was delivered! And when I drained 7 litres of emulsified oil from the sump! This turned into a rubber gloves and gumboots job! The cylinder head was warped 0.012"and its hardness was down to 73 Brinell. Unusable. The engine had obviously been over-heated. Coolant had leaked into the electrical contacts in the coolant level alarm at the base of the expansion tank so it would have been disabled. And the O-ring in the temperature sensor at the rear of the engine was degraded. A classic case of neglect. It also cast doubt on the condition of the block, and it would take a full strip down to evaluate this.
I bought a used N13B16A engine from a wrecker who claimed it was low mileage. I knew that I needed to transfer the turbo charger assembly to it as it came without an exhaust manifold. But I then noticed that the replacement engine had no oil cooler on the oil filter housing, and no oil level sensor in the sump. Its engine number was A276J068 whereas mine was A993J465, so mine was quite a lot later in the sequence. I am now thinking that it came from a 116i, as I understand that these do not have the oil cooler. I can transfer the original oil filter housing and sump to the replacement engine, but am wondering if there are any other complications in store that I an unaware of?
