1 - 20 of 28 Posts
The car went in for a service 1000 miles ago ..they recorded the tyre levels at 4mm
today when washing it I noticed it was already at the stoppers...so 1.6mm
that's a lot of lost rubber for 1000 miles..
is it just a bit of extra slipping in the cold weather wearing them down quicker ??
245/35/18 continental sport 5 MO fitment
How many miles had they done to wear down to 4mm?
Is the tyre wear equal across the tyres?
2.4mm in 1000 miles is way too much, the equivalent of less than 3000 miles for a set from new to completely done.
I'd question the measurement 1000 miles ago, or you've been doing donuts.
i may be doing the donuts involuntary until they are changed...
If your down to the wear indicators I'd be looking to change them pretty quickly. False economy to run around on them at this time of year. The roads are bad enough with all the salt and rainwater on them round my way as it is . One uncontrollable 'drift' and you could end up with a bill far outweighing a set of tyres. .... I replaced all 4 with axons and had a full hunter alignment set up for £295 cash. Peace of mind and all that.
Ive done 5k on a set of Nexens and i cant rate them enough. The wet grip is fantastic, like night and day compared to the bridgestone run craps. To be honest i was a little sceptical until i took the plunge, and i will be putting them back on again.
windyred said:
12000 miles they have lasted...I'm not sure what to get next..the amount of miles I do a year..I Need something that lasts longer
Sent from my SM-G925F using Tapatalk
12,000 miles to me is great, especially on a 123d.
As said Mich. pride themselves on producing tyres that last the longest and provide the most comfort..
I can vouch for Nexen's too.
My last set lasted 16k and absolutely brilliant in wet & dry conditions :)
Reading the reviews on Tyre review, it's rare to see owners slate tyres. Nexens have a lot of unhappy customers.
Having read some test in the past, they haven't done so well.
The problem is a lot of people take old worn tyres off a car and any new tyre feels like an improvement. It's not genuinely the case.
18" tyres are cheap enough. I really struggle to see why people take a chance for saving a small amount of money over the life of a set of tyres.
· Super Moderator
Nexen thoroughly deserved the negative press for their older offerings. However, the new Nexen NFera is actually rather good. They do have a lot of reputation building to do now - but so did Skoda!
I have them installed on a Subaru Outback 3litre, not my 135i... We also have them on a Forester Turbo and they are better on these cars than the Yokohamas they replaced.
Contis do wear fast on quick BMWs, but they grip really well. I was getting though rears in well under 10,000 miles. Their side walls are also quite soft, so I trashed two tyres in pot holes - very expensive! (Had they been Nexens, they would have been replaced, minus the cost of the used tread, at Nexen's expense).
I have now been using Vredestein Ultac Vortis on my 135i, for about 8000 miles. They were recommended to me by a friend who uses them on his RS4. They are excellent in the dry and feel slightly sharper than the Contis because their sidewalls are a tad stiffer. The rears are now becoming a tad more wriggly in the wet - they don't get the power down as convincingly as the Contis. However the back tyres do look as though they will give another 4 or 5000 miles.
The Vredesteins were cheaper than the Contis and they do wear better. They are worth considering.
Discussion Starter · #17 ·
depends what you class as cheap...my rears 245/35/18 seem to be more expensive than most
I can see premium brand tyres starting from £100 in your size. That's a little more than the M lite tyre size.
I see the Nexens for about £50 each. I don't see saving £100 over the life of a pair of tyres as a significant saving.
Discussion Starter · #19 ·
where do you see these tyre prices ??
1 - 20 of 28 Posts
