The car came with EBT from new so no didn't code it. As for me creating an FSC code, I mean I just queried to the car to retrieve it and then used it to upgrade my maps to 2016-1 which worked fine.Wibbles said:Have you coded EBT? Try that first then plug your phone in and launch Tunein radio or another compatible app. See if the app appears in the connected drive menu.
There is a menu item on the left hand pane for FSC status, click on that and then there is a button to read the current status IIRC.
You won't be able to create the FSC code as far as I know.
Well it works in !!, thanks (however not like it does in our 420d), I plug my phone in and select it in the MEDIA selector screen and sure enough it plays through the car speakers, I can also Bluetooth stream it using the EBT of course.Wibbles said:I expect your wife's car has a later version of nbt firmware. Let me know how you get on![]()
No I dont get any of that at all... I just have to choose my USB connection from the MEDIA selector and then it plays TUNEIN that way (no visual indicator at all just sound through the speakers.Wibbles said:So if you go into connected drive after connecting the phone and starting the app, what happens? Does Spotify appear at the bottom of the list? When using Spotify do you get the same app interface on the idrive screen?
No I dont have either so yeah probably missing 6NR (will check later)Wibbles said:Spotify wont come under the multimedia menu, it will either be under Radio or the Connected Drive menu.
If it isn't under either of those menu's then you don't have option 6NR - BMW Apps and will need an FSC code importing into your NBT via ESys to make it work.
so you mean that i can add 6nr without code?? i just coded in 6ns from 6nh in my 2012/10 car with navi pro and it works perfectlitany said:6NR can be added to any CIC with Combox or NBT, without buying FSC from dealer.
Have you got any pointers on how to do this? I've got an ENET cable and E-sys working etclitany said:6NR can be added to any CIC with Combox or NBT, without buying FSC from dealer.
