1 - 12 of 12 Posts
I have a 2005 120d se. In the menu, the temperature was showing as getting no hotter than 70 degrees, roughly. So I replaced the thermostat. It will only go hotter than this when on the motorway, where it goes up to around 86 degrees. As soon as I come off the motorway, the temperature drops to around 75 degrees and stays around there. Anybody any ideas what's going on?
· Super Moderator
I'd change the EGR 'stat as well. Luckily it's the cheap and easy one. Right on top of the engine too, so you shouldn't even lose much coolant. :)
Might be 11717787870 plus 11532248435
· Super Moderator
As it's an inexpensive part, I'd just try your local BMW parts counter (unless that's a long trek).
If you're in the sticks, try Phil at Cotswold BMW for a good price. Email: [email protected]
Gee, I thought a replacement of the main thermostat would have fixed this problem, would not have thought there was another thermostat in the system. I'm learning a lot here!
Can anyone post up a flow diagram of the coolant system?
RegardZ.
Oh! yes I do... Sorry, the petrol engines don't have a EGR... Thanks for subtle reminder.
Delete request for "Coolant flow N46 diagram".
RegardZ.
1 - 12 of 12 Posts
