1 - 16 of 16 Posts
· Super Moderator
There are a few options you might be able to code:
Parked car ventilation
Seat belt chime
Seat belt reminder idrive
Disable idrive disclaimer
Select idrive default screen
Drl option in idrive
Auto light control idrive and non idrive
Enable video play while driving
Auto key fob eject from socket
Engine start without clutch
Disable key hole alarm
Alarm beep on lock/unlock
Window safety feature
Fold/unlfold mirror + roof with fob
Disable bulb warnings
Any light on as welcome light
Corner delete mod
Drl tail light delete
Follow me home lights
Climate dont turn on in auto mode
Digital speedo
Headlight washer disable
Fuel tank warning increase/decrease
Instrument cluster light always on
Sms management from head unit
Gong when key left in igniton
Wibbles is the man to speak to, but he's a very busy man and definitely doesn't owe anyone any favours! :lol2:
Discussion Starter · #6 ·
Because it pops out around a quarter tank, which is still around 12-13 litres of fuel. That gives you a real range of approx. 200 km.
It would be better if it would pop out with 6 litres of fuel in the tank and a real range about 100 km.
I did a check with carly and you can bring it down to 6.5 litres, althoough I'm not sure how you would do this NCS etc.
I have the Dcan cable but to be honest it frys my brain thinking about it all !!
Carly does it for you !!
I did it using the carly app because it's really annoying.
Took all of about 30 seconds. Much better now!
Kimitech said:
Would be great to have a "how to" in NCS.
Not everybody has a Carly, those who already have got a cable would seriously appreciate it.
Trouble is the brief flirtation I had with it and it wasn't Vagcom so sulked off to carly.
Add in carly let's me do it wirelessly with minimal hassle and it was never gonna take off.
But yeah a guide would awesome as I'm not a complete retard the digital age car systems.
Something else I read/heard...
IN the manual it says something like, fill up when you hit reserve otherwise damage may occur or something like that.
Now I've run cars well into the red, but someone said/read that on some fuel pumps, they are cooled by the gas in the tank.
so if you run it too low, there is a danger of the fuel pump failing prematurely.
Not sure how true that is
I'm hoping somone can advise
Blackbmw120d said:
Why would you want to decrease it. Last thing you want to do is run out of go go juice.
ahh here we go
The gasoline acts like a coolant for the electric fuel-pump motor, so when you run very low, this allows the pump to suck in air, which creates heat and can cause the fuel pump to wear prematurely and potentially fail. The repair could end up costing a couple hundred dollars to fix-much more than the $4.00/gallon fill up.
source: consumer reports
1 - 16 of 16 Posts
