I don't have one, but am interested in the Innovv K1 (aka Koonlung K1S).
How do you find the picture quality and ease of use?Paul CS said:Mobius is the one. Do a search on the main forum and you'll find lots of info.
Here is mine...
Paul
That's perfect. Answers everything I had to ask you, so I'll order that one along with the hardwire kitPaul CS said:Picture quality is proper 1080p and very good handling of light. Video looks great on a 55" TV.
I like the Mobius because it is fit and forget. When you need the footage, just ping out the micro sd card and pop it into a computer. If you want to get into deep settings then the software is easy to use.
There are cameras that do more but I did not want GPS speed etc. I just wanted the assurance I have footage should the worst happen and wanted it to be discrete.
Hope that helps.
Paul
ThanksPaul CS said:Mobious dash cam install
Have a look at page 3 thread 45 (on tap talk)
Paul
Thank you!Sutt said:You can currently get the Mobius with wide angle lens from Banggood.com for £45 with discount codes.
If you go here and register () you will receive a $5 off code.
This camera will come as standard where as if you were to buy it from carcamerashop.co.uk it would be already set-up to function as a dashcam.
Paul CS on here has print screened the settings which he is using on the Mobius so all it would be a case of doing is downloading the Mobius software and changing the settings for it to operate as a dashcam!
Downside is that it doesn't come with a long USB lead so one of these would need to be picked up!
