What device are you running through the Aux?
Is your cable pre-amp, or one of those crappy 3.5mm to 3.5mm jobbies?
Yeah that's normal, getting the pop when you connect and disconnect. I echo what Marco has saidjrenwick said:No crackling when there is no music playing, only on bass periods of music. There is a popping sound when I plug the source into the Aux cable but only the same sound as on any system.
