1 - 6 of 6 Posts
Hello
So my car (2013 model with Cruise Control) has the SET button instead of the LIM button on the steering wheel and I want to code it as LIM as I think it will be more useful to me.
I found this " onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; which Wibbles posted on another thread from some time ago.
I just wanted to know if this is everything I need to do in order to code the button and if it works or not?
Thanks in advance (Wibbles Im sure you will reply before anyone else does :D )
Discussion Starter · #4 ·
I managed to get this coded, I only needed to change one thing in the end and the LIM works a treat now.
Word of warning though - It does throw up a traction control and TPS error when you code it, followed by drive safely to BMW message (almost cr***ed myself)
Simple ignition off and back on again solved that ... phew!!
Thanks guys
Thanks guys
What did you have to change in the end?
Discussion Starter · #6 ·
LIM Button (In Place Of SET Button) - WILL THROW TPS & TRACTION ERROR ON DASH
ICM > 3000 DATEN, F8 > SLD_FUNKTION > AKTIV
ICM > 3000 DATEN, F8 > C_UMSCHALTUNG_ACC_DCC > ZUGELASSEN
KOMBI->3003 FZG_AUSSTATTUNG, 10->SLD_ENABLE->AKTIV
1 - 6 of 6 Posts
