It's quite common on turbo charged cars and we have 2 turbos, I wouldn't be too worried as long as your not using oil
No not using noticeable oil, topped it up once since I bought it in early septmever and obviously done the oil service today. Just see it and thought crap. Didn't look nice either seeing a oily pipe. Lol.rob180bhp said:It's quite common on turbo charged cars and we have 2 turbos, I wouldn't be too worried as long as your not using oil
Awesome thanks mate. Luckily mines on second line and says ok.stevesurrey said:The marks are just like they would be on a dipstick with an upper and lower mark. So when full it should be up to but not past the 2nd mark and say "OK" underneath. If it says ">MAX" underneath the oil level is too high and this can damage the engine (alledgedly)
Yea I've seen these and may upgrade this if it'll help.seanklein said:Read up on the N54's PCV setup, this will explain the oil in your intake system.
The fact oil residue is leaking from a 'sealed' pipe shows one of your couplers isn't tight enough and is leaking.. Give it a quick check over.
That's the solution I'll going for when I commit to it. Make sure you buy a carbide tap. Would hate to snap one in the head. Make sure you have plenty time though, long list of things to remover taking the valve cover off.Beasted said:Yea I've seen these and may upgrade this if it'll help. Do you think it's just a case of checking all the couplers making sure each one is tight? Any idea which ones to check? Thanks seanseanklein said:Read up on the N54's PCV setup, this will explain the oil in your intake system.
That one looks good for carbon deposits also mate. Will look more into this and chuck them a email.seanklein said:Sorry, I mean this is the rb kit I'll be doing..
Meaning there'll be no more blow by in the intake system.
