Hi there,
I want to code the following functions but aren't sure if it's possible and if so, where to look. I have a Carly adaptor and the app and I can set up NCSExpert if required (I already have INPA running).
1. Steptronic box. In auto mode I want the current gear to be displayed next to the D on the dash (e.g. D1, D2, etc). I've seen it in videos but can't find how/where to do it.
2. Brake pedal to start. I hate having to press the brake pedal to start the car, it's such an idiot feature it's insulting (you can only start the car in park or neutral anyway). Carly has the option to disable this function but it doesn't work properly... Carly does something because I can hear the starter relay click when brake pedal is coded out (it doesn't even get power when brake pedal is required) but the starter motor doesn't fire. It's as if one interlock is disabled but we run into a second. Any hints? BTW - this is a perfect example of why the Carly annual subscription is such a rip-off, the software isn't anywhere near as polished or comprehensive (or comprehensible) as it should be for the premium price - avoid it until they drop the price by 90% (in fact it should be free with their over-priced adaptor).
3. Auto lights. When i set my lights to 'auto' the main beam (not high beam) and angel eyes all light up, regardless of the amount of daylight. If I set the lights to '0' the daylight running lights operate as expected (angel eyes only). Can I code it so that when in 'auto' mode and it's daylight only the daylight running lights light up (i.e. not the main beam lights as well)?
I'm happy to explore other threads if you have some pointers.
Cheers.
Cheers.
