Hi folks,
Second issue I've ever brought to the BMWBaby forums so hopefully I can get the help that I need.
I have a 59 plate 116d.
Jumped into the car yesterday and put the fob in and received the audible ping followed by the below warning light (worth noting this is an image I found on google images and not an image of my vehicle so the info under the warning is irrelevant. I just used google to be clear on what warning message I am getting)
None of the top display has anything lit up so the manual shows this could be caused by:
- Control of the brake lights failed
- Fuel supply faulty, or
- Electrical system of towing hitch failed
The problem I have is I can't put it down to either of these.
- The brake lights seem to be fine. I tested them straight after the warning appeared.
- Not sure how I would test this, but I don't seem to have any fuel delivery issues
- I don't have a towing hitch
What I did yesterday, and also this morning when it happened, was drove a few miles, stopped the car, engine off, key out, door open, door closed, locked car, then started as if I was fresh going into the car and both yesterday or today the warning didn't come back...
It has been rather cold where we are, minus 1 celcius overnight and around +1/2 degrees when heading out in the morning... Could it be caused by the cold weather and really there is no fault?
Any advice would be appreciated?
