Hi all,
Set of high line OEM dark line rear LED lights for E81/E87.
  • Fitted with a full set of Osram LEDriving Premium LED bulbs which cost around £70 in total (there is one bulb missing however).
  • Comes with all original packaging from Cotswold BMW.
  • Brightness is spot on with these.
  • They are plug and play if you have Xenon bulbs.
  • For the LED bulbs not to throw bulb warning errors you will need to code out the voltage monitoring which can be done easily via app based coding just as the current models are with LED setups.
  • Looking for £250 excluding delivery but open to sensible offers.
