BMW 118d 2007 high mileage/towing car maintainance log
1.4K views 22 replies 4 participants last post by  Enshiu
#1 · (Edited)
Hi all. I want to add my maintenance log here
It has a full BMW dealer/specialist service history
Mileage is getting high now 380000km
Every time I change oil the annual inspection is done
I do 10000-15000km oil change as I tow a lot
A lot to do on this car:
Steering inner tie rods
reacting arms bushings
brake lines all tunnel to rear
rear subframe powdercoating
broken lower engine panel
engine bonnet wont lock sometimes
seats hard as plank (need leather comfort seats)
reprogram airbag ring
washer head loose
310mm brake kit front?
Done:
12-10-2019 bought car for bargain
oil change 09-10-2018 (insp)
new brakes 10-10-2018
new brake fluid 10-10-2018
new tyres 10-10-2018
oil change 20-09-2019 (insp)
new battery 21-09-2019
new front windshield 30-10-2019
new licence plates 3d 02-11-2019
new gearbox oil with MTF-1 and new diff oil 75w90 LS5 02-11-2019
Installed new shift knob and removed the counter weight 20-12-2019
F20 wheels and new tyres 20-03-2020
new wipers 02-04-2020
new 4000k LED interior lights incl glovebox and boot 20-04-2020
used oem right side headlight due leak 03-05-2020
new blue mirror glass 02-06-2020
installing cruise control 03-07-2020
installed tow hook 02-10-2020
oil change 02-10-2020 (insp)
installed green filter 02-03-2021
installed led projectors and high beam led 02-10-2021
new glow plugs and relay 03-10-2021
oil change 03-10-2021 (insp)
new rear lights bulbs 03-10-2022
A/C filled 03-10-2022
oil change 03-10-2022 (insp)
A/C condensor renewed 02-10-2023
installed front brake line and hoses 02-10-2023
oil change 03-10-2023 (insp)
rear windows blinded 29-10-2023
rear suspension and springs renewed 06-03-2024
Installed new serpentine belt and idlers 06-05-2024
Installed all coolant hoses, waterpump, expansion tank and thermostat (radiator new leaks) 06-10-2024
removed p/s fluid and flushed it 06-10-2024
Here is my car:
#12 ·
Wow, you must really love your car, as it’s had some serious maintenance and money spent on it. Great history and write up. I’m sure the maintenance knowledge you have will be invaluable to other members here, thanks for sharing 👍
  • Like
Reactions: Enshiu
#14 ·
Keurige wagen maat, zo mooi onderhouden zie je hem zelden hier in Nederland. Ik ben ook geĂŻnspireerd om nu ook te gaan kijken naar de serpentine belts en idler pulleys.
Hoop dat deze ver over de 400K gaat lopen!
Translation:
Neat car you have there mate, you rarely see it so beautifully maintained here in the Netherlands. I am also inspired to now look at serpentine belts and idler pulleys.
Hopefully this will run well over 400K!
#19 ·
I ordered used calipers from a 2006 520D E60
They are a little bigger and should fit the 16inch wheels as E60 520D came with 16inch.
so 310mm discs and pads will be fitted to have a try.
For 60euros shipped both lets have a try.
Meanwhile I got my 284mm set in. If the 310mm set wont fit I will return the discs and pads
#20 · (Edited)
So the distance between the brake holder bolts are 12cm and E60 is 13.5cm so I need also the hub this time.
With the E60 hubs it will be a lot more choices than E8X and E9X brake caliper choices and brake diameters for 16inch.
Brake pads are done they are cracked due maximum gross weight (1300kg + 1200kg + 600kg > 3100kg)
#21 · (Edited)
after 5.5yrs bought a rear shelf due missing
Got my brake discs and pads bedded in as per Zimmermann procedure:
Brakes much harder and not glazed now.
They are quiet no noise during braking as I used the low dust pads.
It does bite a lot harder compared to the old ones.
