1 - 12 of 12 Posts
Hi everyone..
As titled my key fob slot needs replacing.
The mechanism hasn't ever locked the key inside. Been like that for a while. So under any heavy throttle or over a hump my key flies out loool its become quite a bother now and I think I want to get it sorted..
I've pm'd cotsworld for a quote and I've had a look around eBay.. There's a few out there second hand.
1. Has anyone ever replaced there's?
2. Is it just a easy remove and replace with the part whether it's new or second hand part.
3. Is there any programming required?
So there's quite a few part numbers there..
4. My car is RHD which number would be the one most appropriate for me to be matching against.
Any advice would be appreciated.
Thanks in advance. :)
Blackbmw120d said:
Plug and play. No coding but always disconnect the neutral from the battery first.
Pop out the center dash vent.
Push out the key holder
Unplug the wiring harness
Refit in reverse.
THAT WAS QUICK
Thanks mate.. That's great to know..
Any idea which part numbers I should be keeping an eye out for from the list I've posted above.
Would it be the fourth one down on the list?
Anish1993 said:
THAT WAS QUICK
Put the last digits of your VIN on REALOEM.com and see what part number(s) come up.
Discussion Starter · #5 ·
Sonic1506 said:
Anish1993 said:
THAT WAS QUICK
66129172370
Found it thanks
Discussion Starter · #6 ·
My part came today £15 in eBay very good condition
Gonna fit it now.. I just stuck the key into it now for a test lmao and it doesn't seem to be clicking out..
So what's the how to with this?
Any guides available
Discussion Starter · #8 ·
Mission complete problem fixed and a little how to.. I couldn't find one when I needed so why not.. Not the greatest but yeah
First remove this trim
I had to remove my stereo and heating controls so that I can access the screw that I've shown.
Heating control literally pops out and stereo was held on by two Philips screws
Pull back the trim I'm holding which will reveal these two screws are holding the ignition slot into place.. Remove them
It literally pops out after
The wire disconnects with a little tug
Reverse steps and you're done.
Hey sorry for old thread revival, my key wont eject as well so i bought replacement one and it does the same? can you or someone confirm after its plugged in, it does eject? I think mine i just unplugged and thats why it wont pop out.
Thanks Very much for the instructions!! It works perfectly after replacement. Saved me a 100$$.
I didn't have to even remove the stereo or the heating controls !!
1 - 12 of 12 Posts
