Different intakes often cause lean running and misfires/lumpiness, particularly around 2,000 rev/min.
Running JB4 map 5 at the time.Chazclark2 said:I think a lot of the problem is on unmapped cars with intakes, some cars are fine with an aftermarket intake and OEM ECU settings, others arnt.
You've basically altered the amount of AFR by a big margin and the ECU must be wondering what's going on and trying to adjust to it, I suppose it depends how much air the individual intake brings in as other intakes have had more success, I bet if you (presuming you arnt already) went and had a proper remap the issue would go away because the tables for the AFR could be altered to account for the extra Air being sucked in.
So did I br0wny did a bit of reading up on it before ordering and was under the same impression all issues had been resolved by BMS.br0wny said:Been many that have removed bms intakes for said issues. But I thought they had sorted them now?
The car feels fine every other time just seems to be when cruising around the 70 2.5k revs mark. which is a shame as i agree sounds awesome.Sustanon250 said:Definitely an issue with the BMS intake !!!
My car definitely has a jerkiness to it since installing the intake, it's only on partial throttle and cruise control when accelerating gently ; on wot runs its fine.
I love the intake , it sounds fantastic , but unfortunately I'm going to have to remove it this week.
Good advise BP didnt even cross my mine changing the map. did have a look at the MAF when switching it over looked all clean and shiny to my eye. that vacuum pipe was a right pig to get off though.Blind Pugh said:Josh,
What you might be experiencing could be one of 2 things before changing back to stock airbox:-
MAF sensor;
Higher flow across MAF and increased AFR should allow DME to adjust fuel/ign to keep engine, on constant throttle, sweet. If MAF is faulty or dirty. Suggest give the MAF a clean with contact cleaner and re-install
Map 5 autotuning
Once MAF is cleaned, go out and switch to map 4. See if it still does it with JB4 in bypass mode. If OK means MAF is OK, try it on a more absolute map ie map 1 or 2. If still OK, switch back to autotune map 5 but suggest doing 3 x WOT runs 3 or 4th gear to wake up map 5 to set higher boost targets etc.
If still an issue - 2 solutions
1. ditch the intake and return to stock airbox or
2. code out the MAF, to see if going "MAF-less" cures the issue with BMS intake
BP
Yep - same as mine - it's especially noticeable when using cruise control , up hill , between 60-70 . Every so often the car hesitates . I'd remove the intake and contact Terry at BMS for advice .Joshc219 said:The car feels fine every other time just seems to be when cruising around the 70 2.5k revs mark. which is a shame as i agree sounds awesome.Sustanon250 said:Definitely an issue with the BMS intake !!!
Mate , I didn't have the jb4 fitted in the end (it's a long story ) !!!!Blind Pugh said:Sus - did you install BMS intake before JB4 and did your symptons occur prior to or since Jb4 install. What JB4 map are you using ? BP
Dont get me wrong it a quality piece of kit very well made. and I felt it did make a difference both in sound and a little of performance.DFKMT said:And I was going to order one of these in the morning [LOUDLY CRYING FACE]
Sent from my HTC One M9 using Tapatalk
Some cars will tolerate one, most go tits up. You might be lucky?DFKMT said:And I was going to order one of these in the morning [LOUDLY CRYING FACE]
Was it a straight swap MP? I notice it doesn't list our cars on the page, notice any difference?marco_polo said:Some cars will tolerate one, most go tits up. You might be lucky?DFKMT said:And I was going to order one of these in the morning [LOUDLY CRYING FACE]
In the end, I got one of these instead:
