Hi all,
Long time lurker, now ive an issue that I couldnt get an answer for.
2006 120d M47 E87
Here's a bit of background. I left the car sat for around 3 weeks as I was away from home.
When I got back I got the battery on a charger and reconnected it. The car started up away I went. All good.
Next day, did about 40 miles in it and replaced the headlight bulbs and did 40 miles home again. All good.
The day after that. I did a short journey. Less that 10 miles and on the road home I heard an explosion. No dash lights or anything just a bang. Pulled the car into a car park and found the BST at the battery blown apart.
I disconnected everything, noticing the bolts were very loose. I hadnt torqued them down when i tpok it off charge. ANYWAY, I reassembled it all. The car fired up and I got home. I then took to out later to the shop to check if it was alright. Got about a mile and I got the red battery light, abs, steering dash lights. The BST had came apart again.
Ive gave the battery a much better longer charge and installed it back into the car. No warnings and running fine.
I expect i'll have to replace the battery.
My question is: did the bst fire from heat generated by the loose connections and is it okay to rejoin the bst connection and continue driving?
Disclaimer: I am aware this may be a safety issue if I have a horrific crash and somehow it bursts into a fireball with me in it. In the event of this your reply will not be used on a court of law.
2006 120d M47 E87
