^^ this.GMballistic said:Not sure if their on here but doesn't look good for that M140i.
Could be the head gasket has gone, a damaged/cracked cylinder head and/or block or possibly something else serious. Definitely looks like it's burning coolant though hence the white plumes of smoke.
The owner has since responded as well as another person trying to be helpful.Jahjaman said:I initially thought condensation in the exhaust - but as soon as those huge plumes came out when he gave it a bit of gas, that definitely looked like eating coolant.
I still think your original thoughts makes more sense.GMballistic said:The owner says it's not losing or using coolant so the other guy has suggested it could be a blown oil seal or even blown turbo.
Although if it was the latter I'd have thought he'd definitely get a "yellow triangle: do not drive" alert on the dash. :?
Yep me too tbh.Jahjaman said:I still think your original thoughts makes more sense.
Edit: sorry I just re-visited the YouTube video and noticed the responses.
You must be joking!dailydoggy said:Cold night and engine and exhaust moisture burning off to me...
My E46 was as bad as that in winter....GMballistic said:You must be joking!dailydoggy said:Cold night and engine and exhaust moisture burning off to me...![]()
Apart from watching the full video which I hope you did have you read the video description?
This is definitely not just condensation related, come on.
Yep I thought this too. I had already mentioned moisture in the fuel/bad fuel to the owner in the video comments.dailydoggy said:would not rule out moisture in the fuel or tank/iffy fuel......
We had 30000 litres of diesel at work from a refinery once full of water everything we filled shut down and would not restart..Jahjaman said:Yep I thought this too. I had already mentioned moisture in the fuel/bad fuel to the owner in the video comments.dailydoggy said:would not rule out moisture in the fuel or tank/iffy fuel......
Hhhmm I've never seen a car give off that much condensation ever but I hope you're right for the owners sake.dailydoggy said:My E46 was as bad as that in winter....
If that was smoke it would drift across the car park but it dissipating in and around the car in close proximity...
Big 6 E46's were notorious for it.. Twas a regular bricking themselves kind of posts during winter on another forum i moderate on...GMballistic said:Hhhmm I've never seen a car give off that much condensation ever but I hope you're right for the owners sake.dailydoggy said:My E46 was as bad as that in winter....
If that was smoke it would drift across the car park but it dissipating in and around the car in close proximity...![]()
I still think it's something worse going on but I might be wrong.
