1 - 20 of 51 Posts
Looks good Dan, time will tell if you get any rubbing I suppose, hopefully not. Did you just stick with oem sizes up front? I'm yet to change my tyre sizes, will wait until the worst of the weather has passed.
Discussion Starter · #7 ·
Yeh still oem tyres as they're only half worn. Ideally I wanna up to 235/40 ps4 maybe.
Sits really well. The girlfriend has a set on her F31 but they've been introduced to the kerb too many times for my liking. Might test for one on mine at some point, see how it looks
Discussion Starter · #13 ·
bluebro said:
403M's, 8.5J x 19, ET 47 on the rears.
Mine are 18x9 et44 on the rear.
Discussion Starter · #14 ·
Discussion Starter · #16 ·
Devil84 said:
Any issues fitting 255 tyres on oem alloys on standard height car?
not sure but i think theyd look a bit daft if mine look like that on 9" wheels
Many JDM guys in the US and Jpn run 255 and 265 on 8" rims for a track set up so they have wider contact patch.
They will fit and you will have more sidewall "bulge". The reason 245 is quoted as max. for 8" is the bulging sidewall effectively reduces sidewall stiffness and stability. Can make higher speed cornering a bit interesting.........
The track day warriors get round this by running higher pressures. Ride is impaired but this is less of an issue on the track but a literal PITA for a daily driver.
Discussion Starter · #19 ·
Seems silly then :lol2:
1 - 20 of 51 Posts
